MBS206 Posted December 16, 2011 Share Posted December 16, 2011 Tvs are meant to be mounted on walls. Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6154461 Share on other sites More sharing options...
Craved Posted December 16, 2011 Author Share Posted December 16, 2011 Only if they are your walls!! lol Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6154498 Share on other sites More sharing options...
zebra Posted December 20, 2011 Share Posted December 20, 2011 Sending you an email now Chris Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6159485 Share on other sites More sharing options...
Craved Posted December 20, 2011 Author Share Posted December 20, 2011 re-plied Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6159823 Share on other sites More sharing options...
BOOZTJUNKEY Posted February 29, 2012 Share Posted February 29, 2012 Hey Chris what's been happining any up dates on the manifold? I finally have got motivated enough to get some material to do one myself :-) The manifold I'm making will be the same low mount design as stock . I have found a good way to cut merges on the band saw at work I'm using 36 nominal nominal bore pipe who's is the 3mm wall so 42 od I'm going with 4 into one collecter ( when u examine the stock mani u will under stand why I went with the 4 instead of 6 into one ) For my merge I'm going with a 20 degree cut angle as well The manifold will be made out of 304 ss and fully perged for maximum strength an reliability Ideally I want to sit pretty much in exactly the same spot as factory :-) Although There will be a lot of test fitting and trial and error I'm hoping all goes well :-) any pointers? Also I pulled the head off a facked rb20 I had and was gunna bolt the mani to that when welding hopefully it will suck some the heat and won't distort too much All the best Bejay Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6256807 Share on other sites More sharing options...
sluttydriftpig Posted March 14, 2012 Share Posted March 14, 2012 Nice build, i dont think it will warp at all if you bolt it down tight or tack it flat to something just let it cool down 100% before u brake it free Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6273633 Share on other sites More sharing options...
Muff Posted April 2, 2012 Share Posted April 2, 2012 To stop it from warping u can pre heat it and grab a bucket of sand and drop it in that everytime u finish a weld. works well to normalized the ss. especially 304 due to its iron content. Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6300159 Share on other sites More sharing options...
zebra Posted May 5, 2012 Share Posted May 5, 2012 I see you lurking Mr Craved Whats new? Link to comment https://www.sau.com.au/forums/topic/380963-craveds-fabrication/page/5/#findComment-6344443 Share on other sites More sharing options...
