unfortunatley not Andrew lol
that really needs to be laser cut, then CNC milled from the look of it - though im tempted to get the file for the 1uz to T56 file and see what their machining options are, i do have contacts for all this stuff now.
even if the laser cutters did the main work then etched the surface for the milling part you could spend some time doing it manually on a mill.
  • Replies 87
The turbo has bolts atm, would like to keep that if possible....as for the dimensions to the outside...it doesn't really matter, but I would like the center hole for the pipe to suit 3" mild steel pipe rather than 81mm
Chris, go to 10mm plate is what i've been advised by all the exhaust guys.
They see warping issues after use with 5/6mm stuff.
As for gearbox adapters, why the T56? It's a clunky as f**k gearbox. If I could have easily, I would have avoided using it altogether with my LS1 and stuck with the 5Speed.
If you've got a Toyota engine, get the V160 Box.
just did some measuring on matt's old dump pipe (same flange) it is 12mm from the centre hole to the edge and 10mm bolt holes.
Did notice though that his piping is 76mm OD...so not sure what to do there as I think 81mm will be too loose?
V160 = $4500-5000 2nd hand
T56 $1500 2nd hand
Chris
If I ever feel rich...would you be able to do one of these?
http://www.ebay.com....=item2eaded1639
i bought the 1uz one yesterday - turns out its 3 pieces for the 1uz and they recommend steel - so i'll be cutting it out next week :P
lucky we have some 12mm plate lying around :D
yeah exactly
hardest part is going to be welding the pieces together without the 12mm plate warping - might have to bolt it up to the bell housing and weld it bolted up and low heat as its under compression so doesnt have to be a strong weld.
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
