  • Replies 87
  • 2 months later...
Hey Chris what's been happining any up dates on the manifold?
I finally have got motivated enough to get some material to do one myself :-)
The manifold I'm making will be the same low mount design as stock .
I have found a good way to cut merges on the band saw at work
I'm using 36 nominal nominal bore pipe who's is the 3mm wall so 42 od
I'm going with 4 into one collecter ( when u examine the stock mani u will under stand why I went with the 4 instead of 6 into one )
For my merge I'm going with a 20 degree cut angle as well
The manifold will be made out of 304 ss and fully perged for maximum strength an reliability
Ideally I want to sit pretty much in exactly the same spot as factory :-)
Although There will be a lot of test fitting and trial and error
I'm hoping all goes well :-) any pointers?
Also I pulled the head off a facked rb20 I had and was gunna bolt the mani to that when welding hopefully it will suck some the heat and won't distort too much
All the best
Bejay
  • 3 weeks later...
  • 1 month later...
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
