which r33?
a non turbo is pretty good i guess on maintence and fuel....
a turbo can chew petrol if you get it on boost alot and can cost a bit more to maintain
a modified turbo can put a deep hole in your wallet for fuel and maint
also depends on how you look after it as with any car
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-768987
which r33?
Nice car ferni. Yeah a pretty stock turbo r33. Yeah the whole maintenece cost thing is turning me away from this car.....
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769009
My R33 GTS-t gets around 450-500 km off 50L (that's all i can get in the sucker, unless the fuel light comes on with 15L to spare :D) So that aint too bad, depends how u drive it and where. This is coming from 750km off 55L so there is a substantial difference, but the fun is worth the extra :)
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769573
My approx running costs are:
Fuel = $50/wk
Oil = $3.5/wk
Oil Filter = $0.50/wk
Fuel Filter = $0.50/wk
= $54.50/wk
Many people say that Skylines have high running costs, the only big difference I see is the weekly fuel costs (98 octane vs 96 octane = $5/wk) and also they are more thirsty compared to an average car (such as VS Commodore or a Honda Accord).
The single biggest cost is the 'mod bug' (that is when you can't stop yourself modding the car). You can easily waste $1000/mth for 12mths and still not even be half done. If I did it all over again I'd just buy it... drive it to the ground and then upgrade to an R34 GT-T or an R33 GTR and 'then' waste some mulla on it :D
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769679
Thanks for all the feed back guys. How about spare parts are they expensive? I use to drive a Honda and parts were not that cheap. Servicing was around $250 for normal and for major around $800+.
I've got a motorcycle predator so I use that for fun but I also want a car that can be used for fun and a daily driver.
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769771
I'll post up the Driver magazine (japan) figures later, if I remember. IIRC, the r33 GTS-T managed to get worse fuel figures than the GTR!
My r33 (rb20e) daily 'beater' is pretty horrid on fuel (for what it is) - I've always thought of it as too little power pushing too big a car though
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769807
yar, fuel costs are probably a bit high (i find i return teh same milage regardless of how i drive, only getting better milage if i throw a highway run in there)
probaby about 350ks a tank
i get my car serviced regularly which costs 100 bux every 5000ks or so (yay for nissan servicing)
apart from that, my liner hasnt cost me anything in breakdowns or new parts (a new clutch ages ago, was only 450)
oh , insurance and rego and what not, but i dont even notice those costs;
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769818
hondas are more expenisinve imo, especially if you take it to a honda dealership to get serviced.. the good thing about skylines is the community - everyone is willing to help out - alot of the people with them on here know the basics about cars and can service their own, and know what it should / shouldn't cost
servicing won't be as expensive as your honda
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-770227
nmcmahon83 - are you driving it like a camery or what? :/
Haha, well simply yes. I have 1 point on my license until mid-May... do you blame me :) Although accidently got a little sideways leaving uni today, whoops :Oops: But alot of my driving is highway aswell, im upto 500km this tank and counting (got about an 8th left)
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-770441
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
