which r33?
a non turbo is pretty good i guess on maintence and fuel....
a turbo can chew petrol if you get it on boost alot and can cost a bit more to maintain
a modified turbo can put a deep hole in your wallet for fuel and maint
also depends on how you look after it as with any car
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-768987
  ferni said:
which r33?
Nice car ferni. Yeah a pretty stock turbo r33. Yeah the whole maintenece cost thing is turning me away from this car.....
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769009
My R33 GTS-t gets around 450-500 km off 50L (that's all i can get in the sucker, unless the fuel light comes on with 15L to spare :D) So that aint too bad, depends how u drive it and where. This is coming from 750km off 55L so there is a substantial difference, but the fun is worth the extra :)
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769573
My approx running costs are:
Fuel = $50/wk
Oil = $3.5/wk
Oil Filter = $0.50/wk
Fuel Filter = $0.50/wk
= $54.50/wk
Many people say that Skylines have high running costs, the only big difference I see is the weekly fuel costs (98 octane vs 96 octane = $5/wk) and also they are more thirsty compared to an average car (such as VS Commodore or a Honda Accord).
The single biggest cost is the 'mod bug' (that is when you can't stop yourself modding the car). You can easily waste $1000/mth for 12mths and still not even be half done. If I did it all over again I'd just buy it... drive it to the ground and then upgrade to an R34 GT-T or an R33 GTR and 'then' waste some mulla on it :D
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769679
Thanks for all the feed back guys. How about spare parts are they expensive? I use to drive a Honda and parts were not that cheap. Servicing was around $250 for normal and for major around $800+.
I've got a motorcycle predator so I use that for fun but I also want a car that can be used for fun and a daily driver.
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769771
I'll post up the Driver magazine (japan) figures later, if I remember. IIRC, the r33 GTS-T managed to get worse fuel figures than the GTR!
My r33 (rb20e) daily 'beater' is pretty horrid on fuel (for what it is) - I've always thought of it as too little power pushing too big a car though
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769807
yar, fuel costs are probably a bit high (i find i return teh same milage regardless of how i drive, only getting better milage if i throw a highway run in there)
probaby about 350ks a tank
i get my car serviced regularly which costs 100 bux every 5000ks or so (yay for nissan servicing)
apart from that, my liner hasnt cost me anything in breakdowns or new parts (a new clutch ages ago, was only 450)
oh , insurance and rego and what not, but i dont even notice those costs;
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-769818
hondas are more expenisinve imo, especially if you take it to a honda dealership to get serviced.. the good thing about skylines is the community - everyone is willing to help out - alot of the people with them on here know the basics about cars and can service their own, and know what it should / shouldn't cost
servicing won't be as expensive as your honda
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-770227
  ferni said:
nmcmahon83 - are you driving it like a camery or what? :/
Haha, well simply yes. I have 1 point on my license until mid-May... do you blame me :) Although accidently got a little sideways leaving uni today, whoops :Oops: But alot of my driving is highway aswell, im upto 500km this tank and counting (got about an 8th left)
https://www.sau.com.au/forums/topic/38097-running-cost/#findComment-770441
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
