Hey guys,
yesterday my 4wd and ABS lights come on and steering felt abit funny ( prob because of awd not running).
got it home and took this vid ->
first 3 seconds is fuel pump priming, but after that there is this funky noise coming from the abs module, I ran over there to check and could feel the vibrations in it.
I have never ever seen anything leaking from the unit in the 5 years I have owned the car.
I have multiple questions:
1. does the unit just need to be bled/ simple fix?
2. if I need to replace it, is it an easy job? any complications?
3. can I use a 33 s2 unit in a s1?
4. what fluid does it take and how much?
5. Is it safe to drive the car in this state? Ie if I cannot fix this by monday I need to drive to work...
Thanks heaps guys.
Adam
from the research I have done, I believe I have answered some of my own questions for other people's reference:
1. Unit cannot be bled, the normal brake system is what gets bled
2. not sure yet
3. I don't think a s2 will work in a s1 as a s2 has 2 lines that go to the top of the unit and a s1 has 2 bolts on the top instead, those extra 2 lines are attached to the side of s1.
4. fluid comes from brake master cylinder, normal dot3/4 castrol super etc...
5. I noticed especially in reverse that the brakes felt like they were stuck on, I took out the 2 relays in the black box and I still have the abs and 4wd lights on as I don't have abs now, but atleast I can drive to work tomorrow and use the car until I locate a replacement.
I will do a full brake bled and put in new fluid to hopefully see if it fixes it, but I think the unit has probably had it.
anything else I should know?
hey mate i have the same sort of problem on my r33 gtst the abs light comes on sometimes and also it sounds like the abs module keeps running after i turn the car off it has a slight humming and vibration, if i turn the car back on for a minute and then off the noise goes away, any ideas what this could be, the brakes seem to work fine i havn't had to slam them on yet so don't no if abs is even working. any help would be great cheers
hey mate.
I did end up solving this. turns out it was the attessa controller in the boot that had gotten wet from a leaking rear window wiper, there was nothing wrong with the abs unit itself!
see here : http://www.skylinesaustralia.com/forums/topic/220125-r33-gtr-abs-4wd-a-lsdlights-on/
cleaned it up and it is now perfect! I will be post a full tutorial soon.
Not sure because urs is a GTSt if it has a module in the boot too for abs, as you wont have attessa because its for awd's
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
