I reckon they could incorprate the helmet "hard cover" to clip down around the neck, and do away with straps for good.
Currently helmets finish around your lower jaw line / chin. Could be redesigned so an adjustable hardcover acts like a trap-door around the neck instead (if you can visualize it)? As has been shown once a helmet comes off in an accident its a very bad sign, almost certainly game-over for the average Joe.
https://www.sau.com.au/forums/topic/380994-moto-gp/page/2/#findComment-6078066
Also, on that point, has anyone seen all the rubber lining through guard rails in the hills? Someone got decapitated not long ago coming off a bike by having his helmet jammed in between the rail and ground. Nasty.
In the south african gp of 1977, Tom Pryce hit a fire marshall that had ran across the road (yes, in front of Formula one cars... genius)... the fire extinguisher the marshall was carrying hit Pryce in the head and the force of it nearly decapitated him with the strap...
more info here : http://en.wikipedia.org/wiki/Tom_Pryce#Death
-D
https://www.sau.com.au/forums/topic/380994-moto-gp/page/2/#findComment-6078135
a hans device wont really work though. as a rider compared to a driver you need to look left, right, up down and back, not like a car that is mostly one direction and use the mirrors.
it was a freak accident and the fact his helmet came off shows how freakish and severe the crash was. helmets are not able to come off that easy. A tension release on a strap i doubt would pobably have worked in this instance stopping the head getting reaffed bac and twisted, but most likey to come off in 99% of all other crahses whilst the rider is still sliding on kangaroo hide at 100mph or come off Sic's head midway through the collision with collin allowing valentino to finish him off (not far from what happened with a tightly strapped helmet really...
i'm just waiting for "calls to ban" as a typical dogooder overreaction to the accident
yeah youre right i thought about it after i wrote it, if it was too loose to allow head movement it would defeat the purpose...
https://www.sau.com.au/forums/topic/380994-moto-gp/page/2/#findComment-6079475
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
