So I wanted a drift button for the handbrake for drift for my 33, but they arent commonly available. I was getting sick of taping it up at the track and wanted a button that looked good and worked. Not getting too far on the forums I decided to just get one and make it fit. The only other option was pay around $100 for a cusco item that includes an ugly blue alluminium handle: no thanks.
Descresion was the key, so I bought a black (matches the interior) KTS spin turn knob for a Silvia/180 and set to work. Sadly, while it fits a silvia easily, fitting it to an R33 requires modification. Probably why I couldnt buy it for a tenner in the first place. This might not be a textbook approach, but its what I did and it seems to work.
NOTE: This is a guide only, no responsibility taken if you f*** anything up: do at your own risk.
1, remove the handbrake handle
First off unbutton the vinal cover to get better access, then set to work pulling off the cushioned handle. You will soon find this near impossible. After much effort i resorted to carfully cutting it half its length from the underside of the handle, so it won't look too ugly afterwards. Using any tools I could, including flat head screw drivers, pliers and other long thin tools I finally managed to ply it off. The rubber handle cover grips the metal bar very well, so dont worry about any trouble when putting it back on. You might have some issues with the thin shiny metal ring that surrounds the button. It partially spits apart from the underside, so you can split it open a bit if you some room to move when removing the cushioned handle. I ended up pulling the whole handle off over the metal ring, as its attached to the metal handle unit. Dont worry about bending the metal too much, as some of it will be cut anyway. And yeah, you might hack some stuff up a little here, but if your drifting it it probably doesnt matter too much anyway.
2, Unhook the spring
Now that the handbrake handle cover is off, set about prepping it for the spin knob. There is a spring held on by 2 tabs part way down the handle. Use screw drivers to dissconnect them so that the handbrake button no longer uses the spring return function. Unhook and let it sit freely inside.
3, Cut away the metal button surround.
The reason why the spin turn knob wont go it in the first place is because there isnt enough space for it to jam in and move freely. To rectify this I ended up pulling the metal ring part near the button half out (you cant/dont pull it fully out as its part of the hand brake mechanism) and cutting almost 1cm of the metal off almost all the way around the circumfrance. You might even do it all the way, but thats what I did. Jam the knob in and adjust it using pliers, etc so it so that you can smoothly use the function of the handbrake (but just manually now) not how it worked with the spring. It shouldnt stick and it shouldnt come off easily if you pull it. Once you have achieved this, take it out one last time, put the handbrake handle back on, and refit the button. You might need to jam an screwdriver up from underneith through the split cushioned handle and through the metal underneith handle up so as to give the mechanism something to hold it steady so you can probably press on the button. Then fit the cushioned handle: it should fit tightly again over the metal handle, but you can superglue to bit you cut earlier if you wish.
4, Test to make sure everyting works, and BAM, there ya go, drift button function for 1/8th the price of the full Cusco set.
Now get out there and use it
https://www.sau.com.au/forums/topic/381022-spin-turn-knob-tutorial-for-r33/
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
    • Maybe I should have written that a bit better lol. I did come 8th last in English at school during the HSC, ironically spent 2 decades reading/writing specifications and contracts in IT 😂
    • Right, but that's in-cylinder, there's the interaction between that and the TWC which complicates things. Pulling out timing to reduce NOx is a strategy I saw in transitional emissions vehicles like stuff from 1974 or so. The two inlet runner system is interesting but I'm not sure it makes a huge difference as far as emissions goes, is it a tumble valve? I've seen stuff like that even in cars from the late 80s.
    • Hello all,   so i recently swapped out my rb20de neo with an rb25de neo( engine,transmission, wiring and the diff everything) but i just cant get the gear indication light on the dash to work when i switch to tiptronic mode. Note there is a steering wheel switch beside the shifter and i dont have that. I did notice yesterday while switching to tiptronic that the indicator on the dash started to work but it didn't afterwards. Does anyone know how this actually works? Or do i still need that steering wheel switch to be connected and on for that gear indicator to work?
