Crimestopper Remote Start RS-999FMTW1 - asking 250ono
"Dynamic Code" Anti-Code Grabbing Protection
Extended Range On Glass antenna System (RS-900 VI Only)
Positive or Negative Parking Light Output (jumper selectable)
Remote Auxiliary Channel Output for Electric Trunk Release or Optional Accessory
Auto Lock and Unlock with Vehicle's Ignition ( programmable)
Programmable Anti-Grind / Starter Disable Output. Optional Circuit Prevents Accidental Key Grinding & Provides a Starter Disable Circuit for Anti-Theft Capability
Tach Reference or Smart Tachless Modes
Infinity Run Mode - Provides Endless Run Time Through Idle Down
Three Remote Start Attempts
Optional In Dash L.E.D.
Valet Mode for Vehicle Servicing
Multi-Function On-Board Relay #4 Selectable as a Second Ign, ACC or Starter Output (Jumper Selectable)
Diesel Glow Plug Delay Time: Set for Delayed Cranking in 3 Increments :10, 20 or 30 seconds
Transferable Limited Lifetime Warranty
433mhZ High Frequency Anti Code Grabbing Remote Transmitters
"Smart" Tachless Mode - No Tach wire or programming required (most vehicles)
Tach Finder Mode
Remote Keyless Entry (controls power door locks)
Panic Mode with Horn Honk and Flashing Lights
Programmable Factory Horn Output for Horn Chirps and Horn Honk During Panic Mode
Factory Alarm Disarm and Rearm Outputs During a Remote Start
Gas or Diesel Engine Operation
Automatic Transmission Equipped Vehicles
Selectable Run Time of 12,24,36,or 48 minuets
Idle Down Mode Takes Over Operation when Key is Removed
Timed Self Start Mode. Allows Unit to Automatically Start Every 4 Hours
Hood Open Safety Circuit - The Unit Will Not Remote Start if Hood is Open or Ajar
Negative or Positive Glow Plug Input ( Jumper Selectable )
"Timed" Crank Mode: Set for Delayed Cranking time in 4 Increments from 0.5~1.5 Seconds
Horn Chirp Confirmation of Lock, Unlock with Double Button Press of Remote Control
pm me or email me at [email protected]
leave your email for pics.
No box,but everything else is brand new and still in plastic containers. Comes with installation and usuage instructions
https://www.sau.com.au/forums/topic/38103-remote-start/
  • 1 month later...
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
