Hi there:
I want to buy a V35 Coupe door lock actuator (RHS, Part number 80500-AM81A), and am wondering which JDM parts website (apart from eBay) can I buy it from. I've searched the forum as well as in google, but cannot find any.
Appreciate your time and help.
Andy
I buy lots of parts from www.japanparts.com for my v35, never had any problems. If they don't have what you want you can also email them and they will source it for you.
I just had a peek and they have this: Nissan: 80550M/ 80551M ACTUATOR AUTO DOOR LOCK FRONT.
They got pics so see if it's what you need. Hope that helps.
http://www.infinitipartsusa.com/splash/index.cfm?siteid=55
I bought cooling fans and supporting hardware from here, actually phoned up and spoke to a rep. He organised payment through a paypal link and my parts came within 3 business days!
Edited by TUFF_350
Also sewell (email [email protected]) and g35parts (http://www.g35parts.com/Infiniti-G35-Coupe-Parts-s/1.htm )
I've used both. Josh at Sewell in particular was extremely helpful.
I can probably help there. failing that FTG nissan speak import quite well.
<br class="Apple-interchange-newline">Ferntree Gully Nissan? I've just sent them an email enquiry.
Thank you for your help. Will have a look now.
http://www.infinitip...x.cfm?siteid=55
They do have a lot of parts that I'm interested! For example the infiniti emblem kit. And they do have the door lock actuator!!!!
Thank you so much!!!
Also sewell (email [email protected]) and g35parts (http://www.g35parts....e-Parts-s/1.htm )
I've added them to my bookmarks. Thank you.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
    • Far out, that thing looks like some loose fun!  Nothing beats the rawness of a filthy old Nissan with zero aids to keep the wheels pointing in the right direction like modern "fast" cars!
    • If there is no ridge at the inner edge of the battery tray (ie the battery tray is flat until it rolls off the edge into the open space of the bay), then no, it won't matter if it overhangs. If the battery would be propped up by any ridge, then that wouldn't be ideal. The bottom of the battery case would not be sharing the load. It would be concentrated on one end edge and a line across the bottom where it contacts the ridge. And possibly it wouldn't fit under the locking clamp either. I only upsized my battery to the max because: I sometime have to leave my car undriven for weeks at a time while I am away for work. On the previous battery (replaced a couple of months ago) I had to leave it undriven for months at a time!! I sometimes abuse the battery by running the stereo up loud for many hours while I wash and polish it. This is how I realised that the previous battery was on its last legs, because it got to the point where it was too weak to start after a couple of such. It was 7 years old though, so, fair play. Supercheap had a good special so the X was only ~$250 instead of ~$320, which seemed sufficiently less painful. I had already been using NS70 for the previous 2 batteries for most of the same reasons as above. The X is just the final boss level. I was contemplating going LiFePO4. But it's like $900 to do that properly, and while you save >10 kg of weight, you can likely only expect a couple of years longer life. So meh. Maybe when the price comes down further. Although, in ~7 years when I have to replace this one, I might not be allowed to drive such an anti-social vehicle anyway.
    • If I get a larger battery and it hangs off the edge of the frame rail, would this be an issue? With FMIC a lot of people downgrade their battery size due to less room for shit, was wondering if it would affect anything but it would still be tight via the clamp.
