Building up a rb20det.
I have done some head work and shaved about .040 off to raise the comp ratio....... I hope they are not na, cause that might cause problems....
0.040?
I hope you have a good tuner and great fuel
Running stock cams, hx35, and tunning should be fun. I have 93 octain here in the states and can get my hands on race gas. If you see the way the head is made, you will see that shaving that much wont rais the comp up that much. I am looking for 9.0-9.5 to 1. I wont beable to run the same timing, but I wont need to. I should also see boost sooner now, and off boost power will be better.....
Do they sell methanol at the pump :)
Curious to see ur results. I have a rb25/30 here than has 1mm off the head but we will be running that N/A
The rb25 head will see a higher lift in compression when shaved. I am still cleaning the combustion chambers to avoid det from hot spots. Should be putting the head together in the next week or so. Then its on the block and in the car. I will be posting my results here.
Anyone know of any good tuning software that is free or cheap? I have a buddy that is going to lend me his tuning know how, but only uses an power fc right now. I am going to use a chip. I have romedit, just kinda looking to see if there is any more out there.
The EPROM isn't programmable from factory so you will need to install a Nistune or similar
I will be socketing the ecu and burning chips. I plan on using an emulator to tune and then burning a chip to use when not tuning..
No offense intended but why, we were burning chips 10 years ago, nistune is so cheap, the emulator will cost more, and the old school tuning stuff is slow and clunky
When did nistune only cost 150? Look a chip is just as good as a off the shelf ems system, minus a few things. People make crap loads of power on chipped ecus all the time.Even nistune is just lick a chip, it replaces the chip with a small board. Is it the best way to tune? no But it is cheap..
if you've got your own tuner you can pick up nistunes for like 450 check it out here this is for RB20 http://www.nistune.com/equipment-products-type2.php plus you get live tuning and data logging go have a read on the home website...if you ask me the extra 300 bucks is well worth it less of a pain in the ass plug it in and away you go :thumbsup:
You still have to do the same stuff. Remove the chip in the computer, and add the board. Maybe you get a bigger map (16x16 is what I will be working with), thats not worth it to me. I will be data logging with consult and a laptop.
    • @GTSBoy Yeah i know. The RB20 has 180Nm torque and the gearbox "should" take up to 400Nm if you are not doing stuff like drag/drift or dumping clutch and of course then it is pure "luck" on how will it last. My problem is (i think i said this in different post) that my car was very badly maintain so i would not be suprised if the oil in the gearbox was not changed until i bought it. Yeah the gearbox seem little bit sad.   @Sxnjeet the +T seem very interesting but from where iam from it was nearly "impossible" to done right and not blow twice as money as just swap for the RB25.
    • Hi, I went to the MINES shop here and bought something.. Niikura-San just happened to be there so I managed to take some pics and got him to sign my dash surround thingy. Its still wrapped in plastic back home.. I was thinking how to preserve the signature??? Im sure someones thought of this and done this in the past.
    • Perfect - thanks Joshuaho96!  Will see what I can source.
    • If the plastic wore, the paint will wear quicker. Heck, most car manufacturers cant keep the coatings they put on their buttons/trims alive these days for more than 5 years... A cheap paint won't do it!   However, you can get away with high quality vynil wrap, primarily in areas that won't cop much abuse. Skip colour matching, and just try and wrap a specific area with an edge in a new colour.   PS vynil wrapping is a prick of a job, and I suck at it, even for a small dead flat surface...
    • I think this is more a question you should ask the tuner. My assumption is you have nothing plugged into the original pin for ring gear crankshaft, which is where your map sensor should get wired to, but now you've asked the tuner to disable it. I'm assuming (because I haven't memorised your setup) you are using RB25 ECU on the RB20 loom, to plug into an RB25. You will want to check what else is connected potentially backwards between the engine, loom, and ECU. You might be all fine and safe. The best solution you could have done is wire in a map sensor, and leave the ECU able to read a map sensor.
