Anyone able to give me some pointers on where to mount the racing harness?
Its a 3 point harness the rear top straps are mounted to the rear seat beats bolts cant work out where to mount the bottom half of the harness any pointers will be appreciated.
Its in a R34 GTT without a roll cage.
https://www.sau.com.au/forums/topic/381089-some-help-installing-racing-harness/
Use the search function, there are lots of ways to do it but most of them are wrong.
You don't want a harness if you don't have a roll cage either, if you roll the far the harness will hold you upright and your head will act as a roll cage, but with your head made from meat and bone you will be dead.
I'll take a harness in a roll over crash over a seat belt with or without a roll cage any day thanks.
As to the question from OP, the BEST thing to do, is actually grab the CAMS regs on mounting and get the angles right. As for the nut strap, you will most likely need to drill straight through the floor, and put the mount in. You can buy certified mounting plates from around the place that the loop will bolt into.
Before you drill, MAKE SURE you're not going to pierce through fuel or brake lines, or drill straight into a wiring harness.
3 point harness hence no nut strap, only correct way IMO would be to install a harness bar, you can use the bolt on the seat belt slide thing on the right side but you will need to drill a hole in the floor on the left side and use a backing plate.
Look at a few cars that have rolled over, its the top of the seat that stops it from going any further down, if you cannot move out the way its going to be your head that stops it.
Do a risk assessment on it and see what you come up with.
Mark " safety devices that are installed without thought will be just another risk "
In my R33 I have a 4 point harness that uses 3 mounting points.
I used the following:
Front bolt for the OEM seatbelt rail for the right hand side
Rear left seat bolt for the left hand side
Made a bracket that bolts onto the parcel shelf for the rear mounts
I'd take photos when I get home, but home doesn't have internet at the moment :laugh:
Off the top of my head I think CAMS recommends a maximum of a 45deg angle from the horizontal from your shoulders (or something to that effect). Any more than that and the harness will tend to pull you down, puting extra strain on your spine (source: Eric the CAMS scrutineer at the old Oran Park drift days :D) This means that your rear mount from the rear seat belt is not ideal...
In my opinion, a harness with a OEM seat is far more effective in holding you in place that an aftermarket seat with OEM seat belts :thumbsup:
It will definitely hold you in place so you don't move around but that isn't what a harness is designed for, the seat holds you in place, the harness stops you from being thrown around in the event of a accident.
Thanks for all the advice guys i kind of got most of the harness installed except the bottom strap on the left. which i need to buy or create a plate to bolt one down.
I was originally going to use the normal seat belt my friend gave me his harness as a present so i thought i use it just for fun.
Look at the injuries sustained in crashes from front on, side on, and rear on from seat belts, and then from harness.
Then compare the number of total accidents that involve roll overs.
Even on the track, roll overs are the rarest form of accident.
Even if you don't have a roll cage, I'd rather protect myself from the most common type of injuries/accidents...
your lower left strap should be easy..
I ended up bolting mine onto my seat rail bolt as its directly opposite the bottom seat belt bolt and goes along the transmission tunnel unlike most other skylines that bolt to the floor..
Hope that made sense.. Basically to summarise.
bottom left strap - left rear seat rail bolt
bottom right strap - bottom seat belt bolt.
shoulder straps. bottom rear seatbelt bolts or rear child restraints or harness bar ( whichever is best location or available)
If i remember ill take pics of mine tomorrow
You are only going to be using this on the track correct?
If it isn't engineered and certified, and you're using it on the road, you can be booked for it.
In my experience it's a bad idea to use a harness on the road anyway. In combination with my dark tints and my low mounted Sparco Sprint V, blind spots get quite large and only get larger if I can't move my body :laugh:
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
