Right kids...
Thursday is the day for BF3 on PC! Unfortunately Thursday is also the day I head up to Shepp for the SAU Nationals >_<
So come Monday it'll be game on for me...
So who's pre-ordered? Who's gonna be playing?
I know a few of my mates, and brother are all set to rock and roll. So no doubt a fair whack of you lot are!
I will definately organise a BF3 night for us as my work and life is about to quieten down a little leading into Xmas period so intend on getting back into some games :worship:
https://www.sau.com.au/forums/topic/381146-official-battlefield-3-thread/
ill be there gaiz, usual tag of bozodos on Origin
it's not out for Aus yet either, if you're that desperate you could VPN to South Korea or something like that
just installed the newest Nvidia drivers for it (since the beta ones were making my machine hard lock up in everything!)
just lifted this from the OCAU thread, and have gotten it working on mine for early access:
Control Panel -> Internet Options -> Connections -> Lan Settings (Bottom of the Panel)
Tick "Use a proxy server for your LAN" Address: 210.107.100.251 Port: 8080
Click Okay. The via ORIGIN start BF3 and it'll unlock. Then untick "Use a proxy server for your LAN" and you are good to go.
My stupid CD key site says I won't get my key till the 27th.
This is, in reality, a good thing as it will prevent me failing this week's uni exams :P
I'm sherbert86 on origin if anyone wants to have a game over the weekend though :)
haha I was wondering why you keep playing the Russian version Madaz!
Turns out that something to do with my GTX 460 SLI setup is causing an issue; solid as a rock on one card!
Single player is pretty good, but too scripted for my liking, multiplayer is fkn AWESOME! (would have liked more destruction but I guess there are limitations to that)
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
