ive been playing way to much
currently im up to level 39 with all vehicle unlocks done
thats a nice rank youve got going there
no-one in +SiN+ is in the 40's as yet......
GG in tonights scrim - enjoyable
Copy FINALLY arrived. Sure, it's ps3 but I've gotta say, IM LOVIN IT !!!
Campaign is fkn awesome and multiplayer is crazy.
It's been way better tweaked since the beta too. Game runs a lot smoother. And even though it's no PC version, graphics are still pretty fkn sweet. From what everyone was saying, I was expecting nothing but pixels…
There's no interest for MW3. Yes, I have been totally converted :)
I think the key to enjoying this game is NEVER play it tired.
Best way to ruin your stats/create rage :rant:
This guy knows. Once you start raging shit all starts going downhill haha. Apart from that i really love it, its great fun when playing with 3 of your mates!
Deathmatch servers are few and far between the past 3-4 days, but certainly a good way to get unlocks for weapons as it's pretty easy to get 15+ kills in a round that generally doesn't last too long.
Not all that good for overall "points" as a class (except service stars bonus).
Loving Assault. Barely played anything else unless a tank needs killing and muppet allies don't comprehend.
Cozi told me to level the M416 - best move I've made. Works a fken treat in Death Match... When you unlock IR scope its fken ridiculous for Short-Med range combat. Long range is extremly hard to target and its more pot luck than anything.
The 416 is also good when you get the 4x+ scopes onto it as well. Not as good as a long range rifle obviously but still pretty fken potent and I've had great success.
I'll play other classes later i suppose :D
I finally got a decent shot at multiplayer.
I'm still fairly noob. The transport is the funniest to learn.
I was in a chopper and jumped out without knowing which button it is to deploy the parachute - the button didn't appear on screen quick enough.
So by the time I press it, it's too late; my guy lands hard on the ground and instantly dies, and I'm staring up at the sky, only to see my chute fly open post-death.
The kamikaze pilots are a laugh as well.
Oh choppers and planes are farked to use. I still ain't got the hang of it.
Took a lot of people i know a solid 2-3 hours of flying to truly get the hang of it... Im just go gunner, it's easier then :D
assault, or recon.
assault is heaps fun on smaller maps running conquest. and just healing everyone. at one stage i was so lazy, i had a K/D ratio of 2/25 but still managed to get a score of 6k. hahaha, i just ran around reviving and healing
recon is fun, but i kinda feel left out comparing my recon skills to BC2, on BC2 i owned every person in recon! in this i find it a bit more difficult. especially with the very first sniper you start off with on the russian side...... what a nightmare
the other day, i saw one guy es engineer, with a score of 11k on conquest. the next person score wise after him had 4k....... i had a measly 2.5k with recon :(
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
