the tower falling in caspian is cool - happens when 1 team has 20 tickets left
agree
i was running along the field toward antenna when it started falling.
behind the keyboard yelled HOLY F*** and got my character to run in the opposite direction with it just missing my player.
heart was genuinely racing
SO COOL!
Lol I've done the same. Trying to go third person view in a tank and it just wouldn't happen, until I realized its a hardcore server…
Is there anything different regarding bullet damage in hardcore? It's difficult to determine without the health bar.
These are the requirements for the 10 different assignments that each unlock a new weapon in the upcoming Back to Karkand expansion for Battlefield 3:
FAMAS – “Best Friend Forever”
10 Revives
10 Heals
HK53 – “Fixing it”
10 Repairs
1 Kill with the repair tool
QBB-95 – “Let it rain”
20 Kills with Light Machine Guns
2 Mortar kills
QBU-88 – “Specops”
20 Kills with sniper
6 Laser designations
PP-19 – “Familiar Territory”
ARM 10 MCOM stations
10 Flag captures
2 Hours played on Strike at Karkand
L85A2 – “Professional Russian”
100 Assault rifle kills
20 Grenade launcher kills
Win 5 Squad Deathmatch rounds
QBZ-95B – “It goes Boom!”
50 Kills with AT rocket
1 Enemy vehicle destroyed using the repair tool
Win 5 Conquest rounds
MG36 – “Keep your head down”
100 Kills with Light MG
50 Suppression Assists
50 Ammo Resupply Assists
L96 – “Creeping Death”
50 Headshots
50 Spot Assists
5 Knife kills
MK3A1 – “Scarred Veteran”
10 Kills with the PP-19
6 Kills with the DPV Jeep
10 Kills with the BTR-90 APC
2 Hours played on Sharqi Peninsula
2 Hours played on Gulf of Oman
HardCore = No Hud, 3rd person view or 3D spotting, health is set at 60%
Keen to join a clan for BF3 competition ladder matches?
Swing by sinners.net.au & post your application in the recruitment thread.
Friendly bunch of social gamers.
No you want death inc www.deathinc.com.au :P
no neither of those :P you want Cock n Bull gaming cnbgaming.net.au
or sob tea tog yadda yadda
should make a thread where we all nominate a clan and prospective people can check them all out
Ill see you in the SIN v TEA match :P... That is if its on a good day.
Edited by Cozi
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 😁 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
