Hi,
Have just bought a set of R34 GTR wheels, which I think are: 18x9+30
Am after some tires, and am interested in a set that would cost me around $1000.
Looking for low profiles, long wearing, and reasonable grip for general driving.
They'll be going on a R34 GTT
I was looking at a set of Kumho KU31's 255/35/18, but not sure how much they would be, and if they would be suitable.
Thanks,
Jacob
https://www.sau.com.au/forums/topic/381151-help-with-tires/
Have a look around locally then have a look at importing your own, I've used www.tirerack.com in the states, for under $1000 you can have delivered to your door tyres which if purchased in Australia would cost nearly twice as much.
My last lot were Dunlop Direzza 245/45 17 which cost me $145 a tyre( $450 each here) or $930 for 4 delivered to my door, I'm in the process of getting some more tyres at the moment, I'm looking at Hankook RS 3 (?)$120 a tyre at the moment, worth $310 here, even with the $350 delivery and fitting costs I save about $300.
Shipping takes about 5 days.
The only people who will tell you importing you own tyres is a bad idea are Australian tyre distributors for some reason.
Shop smart.
https://www.sau.com.au/forums/topic/381151-help-with-tires/#findComment-6078216
You can get KU31s from Option 1 in Brisbane sent to you for approx the same money as buying from tirerack, without the extra hassle of having to go to the bank and do an overseas money transfer. At the $1000 price point there's not enough in it to make tirerack the convincing choice.
I bought wheels and tyres from tirerack, and because it all added up to a lot of $$, it was well worthwhile. But I bought my last 2 sets of KU36s from Option 1 because it's just that much easier and the extra $50 or so is not worth the hassle.
That said, after you pay to get tires that you've bought at a distance ($15-$20 each) fitted, you start to wonder about the sense. My next set of KU36s I'm just going to buy from TyrePower on Sir Donald Bradman Drive, Mile End. They've promised to match what I would pay in total sourcing them from elsewhere and fitting there. GI'd suggest perhaps you get a price from Option 1, and ring up TyrePower and ask them to match/beat it. I prefer to support the local guys any time I can make it make $$ sense.
By the way, the KU31 will be a good choice for you. They work well, last well, reasonably quiet and comfortable. I'm not suggesting that there aren't other tyres in that space which might not be better, but they are definitely good value. If you move up to the KU36, you will love the extra grip, but not having to replace them twice as often!
https://www.sau.com.au/forums/topic/381151-help-with-tires/#findComment-6078516
LOL @ not enough in it to make tirerack the convincing choice
Dude KU31s are budget tyres whereas the dunlop is the top of line Z1 star spec which is the difference between heaven and earth. KU31 will provide no where near the grip the Z1 star spec provides.
https://www.sau.com.au/forums/topic/381151-help-with-tires/#findComment-6078890
Why are you laughing? It's because he is looking at cheaper tyres that it's not worth going to tirerack. If you'd read my post you would see that I clearly said that when spending a LOT of money, it IS worth going to tirerack. But if you're only saving $50 or so, I'd rather save myself some hassle and just buy locally.
By the way, how long do the star specs last? Their wear rating is 200, the KU31 is at 320. So he'll get many more miles to his $ even if he buys KU31s here at the same total cost to getting the star specs in from the US. And if you read his post, he did ask about long wearing.
https://www.sau.com.au/forums/topic/381151-help-with-tires/#findComment-6080235
I know of beaurepaires.com.au/tyres , where you have the option of inputting some preferences on your tyre needs (e.g. wet braking, dry braking, mileage, etc). They have a collection of tyres you can choose from once the search results/recommendations have been given. On the other hand, you can just directly browse over their car tyre selections. From their car tyres page, there are descriptions as to which each tyre is best used for. Hope that helps!
https://www.sau.com.au/forums/topic/381151-help-with-tires/#findComment-6088655
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
    • For anyone that comes here looking for answers on what can go wrong with gts-4 to rb25detneo swap. The Gloria's awd sump is different and does not fit. The rb25neo from stagea are exactly the same sump bolt pattern and axel alignment. Castings numbers are different on Gloria's blocks and oilpans if they need to be identified.
