Ok I'm going out to the creek on monday so what's the go?
1. Helmet?
2. Long sleeve shirt? Why?
3. Put cheap tyres on.
4. I have an auto/tiptronic. Will I have tranny overheating problems? How do I know if it's getting bad? Just keep an eye on my engine oil temp gauge I guess.
5. It's twenty minute runs I think. Much waiting in between?
6. Anything else I should know?
https://www.sau.com.au/forums/topic/38118-my-first-track-day-what-do-i-need/
1. required, must comply with AS 1698 or equivalent.
2. "neck to wrist to ankle" non flammable clothing, driving suit recommended, shoes must also be non-flammable . i.e. sneakers made of synthetic materials are technically not allowed.
3. heh
4. should be OK, you won't be pushing it that hard I would expect.
5. if there's 3 groups then 40 minutes in between (60/3=20) :(, if there's 4 groups Dave usually runs 15 minute sessions
6. BLEED YOUR BRAKES!!!!!!!!!!! This is the most overlooked thing for track preparation. Nothing worse than having the pedal go to the floor on the 3rd lap because of all the grungy sh1t in your lines and calipers. :D
Check all fluid levels, tyre pressures, wheel nuts, everything!
Contrary to popular belief Frank Williams does NOT recruit at drive days so stick to your limits and you'll have a great time and drive home in an unbent car.
oh and have fun :)
Damn! I all that hard work went to nothing. I really thought I had a chance with Montoya leaving. :)
Keep an eye on your temp guage and you should be good.
If it's your first time out there, get one of the regular trackday hoons to show you the lines. What ever you do, don't get Fatz to show you the lines. He drives on some funny lines that bloke :D
What the... ? Wish you had told me this last time I was at the Creek. Would have saved me about $2,500 in brake repairs :D
Definitely bleed your brakes with brand new DOT5.1 Brake fluid (about $100 inc labour at your local brake mechanic).
I'd also highly recommend asking either a "Driving Instructor" (their are usually 2-3 at the trackdays) or someone whom has been to 2-3 trackdays before to passenger around with you for the first session (or 2). You don't need 1000's of hp to cut a quick lap... you need good lines and smooth throttle/braking. No point trying to put Schumacher out of a job on your first outing, just work on getting the lines right and learning the corners.
When the checkered flag is shown reduce your speed to about 60-80 in 4th gear (for the cool down lap) to help all your temperatures drop. When you make it back to the pits drive all the way out to the main road and back before parking in the pit garage. This will allow your brakes and engine oil etc to cool down. When you arrive back at your garage leave your handbrake off and just throw something behind a wheel. Keep your bonnet raised until your next session is due (about 40mins).
Make sure you remove anything loose from your car; Headunit, Center Console, Glove Box, sub box, spare tyre, jack etc.
Contrary to popular belief Frank Williams does NOT recruit at drive days ....
What the?
I've got one to add :/
Don't go out there trying to set a quick time! Its your first day, get used to how the car reacts on the track, build speed gradually, that way you'll bring your car home straight and learn a heap about driving....
Bob, good to see you're still at it.:P (I was in the purple 180SX at the Skylines Australia skidpan day a while back).
I'd say:
Take some concentrated coolant and distilled water.
Get some cotton gardening gloves if you're going to change tyres. Take some wet-wipes as well. It sucks getting grease and stuff on your steering wheel (as well as being unsafe).
Buy some racing gloves. You only have to get blisters once before it seems like a good idea.
Take a look under your car before a session to see if anything is leaking out after the last session (I noticed burst caster rod bushings this way).
Make sure your battery is secure, since scrutes always check this first.
Take out your floormats.
benm is right. Make sure you let your brakes and other stuff actually cool down on the cooldown lap. I just had my front rotors machined recently after they warped from a trackday at Wakefield because I didn't let them cool down.
Ask people stuff. I asked a lady who drives an awesome (and loud) dark blue RX-7 to show me the right line on the circuit map at Wakefield, and the next session, my average lap time went down almost half a second.
Don't you also need a secondary bonnet release? That's what i was told anyway??
any cams event will require a L2S license, secondary bonnet tie down and a fire extinguisher.
The track days run by motoconcepts, unique autosports, wakefield park etc only require roadworthy car, helmet and long clothes
    • With stone chips, you really can't just try to fill them. You really have to sand that spot to lower the edges of the chip, so that the filler will end up covering a wider patch than just the chip. Otherwise, you're trying to have a sharp edged paint surface match up to some filler, and they just do not sand the same and you always end up with a noticable transition. A bunch of adjacent chips should be well sanded back, to round off all those edges, and use a lot (in a relative sense) of filler to raise the whole area back.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
