I don't have that mobile view option in my settings (galaxy s2).....
Same as above, can browse in mobile but next time I open the bookmark to SAU goes back to full version and I have to go to a section then press mobile version before it will work (pressing mobile version on the main section of the forum just re-loads the full version :S)
  • Replies 41
i too have a galaxy s2, but i just upgraded to ICS 4.0, so that's why i have that other setting.
try opening the site, going to the mobile view and then saving that page as a bookmark. check that the address has something about mobile at the end of it. then close the browser and open it again and go to sau via the bookmark. if it doesn't load the mobile page then hit refresh and see what happens. for me that solves the problem.
No go. its quite strange before the site update it always went to the mobile site through my bookmark
Did you put ics 4.0 on your phone with odin? I'm waiting for the Telstra release which is in the next week or two
I used Samsung kies. Just downloaded and installed kies off the Samsung website, plugged phone into PC with the usb cable (with kies running), it pops up saying an update is available.
Might give that a go after work. I tried with kies on Wednesday and nothing happened. The messaging in ics looks a lot better
But as for SAU, still the same. full version till I navigate away from the main forum page and press mobile version
i'm with optus, so you may not have an update yet being with telstra. text messaging is pretty much the same in ICS as it was in gingerbread. don't like the new unlock screen (if you use the pattern). the cirlces are much smaller.
as for sau, trying hitting refresh once the page loads and see what happens
Yeah tried that. ill just put up with it I guess till the ics update then it might work
I have a Nexus S (android). I was sent ICS as an update a few weeks back.
Cleared cache and and bookmark and started again. Still no go.
Ill just hit the mobile site tab at the bottom of the page. No biggie.
Its been good using the link i posted, only gone to normal site once. Every other time has gone mobile. Sometimes I just have to scroll all the way to the top or the mobile page doesnt display (when navigating around threads) but this isnt really a big deal
  • 3 weeks later...
I have tried every single fix ITT and none of them work.
Anyone got anything else to suggest?
The website has the correct suffix for mobile devices, but the forum wont come up in mobile version at all. Even the "use mobile" button just reloads the desktop version :/
  • 1 month later...
  • 1 month later...
Rather than start a new thread, thought I'd just continue with this one.
The search function on the mobile site bites the big one. It gives the results of the search only as threads, but when you click on the thread with the result it just takes you to page one. Would be nice if it took you to the post that had what you searched for
Since the update, My phone version has been really annoying, It used to be fitted to the screen, Show all the treads nice and easy, Not its like a net full version adn i keep having to zoom in to read something or click something.
all settings on ym phone are fine, Not sure what other to try
    • Well.... it's not just "de-oxygenating". If you do that you just have, most likely, ethane. So you still need to do a synthesis step to combine a number of ethanes/ethanols to make circa-8-chain hydrocarbons. And of course you don't want straight chain HCs, because n-octane actually has a negative octane rating (ie, it's worse even than the n-heptane which sets the zero on the octane scale!), so you have to do some tricky catalytic chemistry to synthesise branched HCs. That's all doable - but it doesn't come for free. And.... it starts with ethanol, which is an agricultural product, and there will almost certainly never be enough of that as a base stock to replace the liquid fuels that are in use. You really wouldn't want to be planning to be using any more ethanol for fuels than is currently already used (in E10, E85s, etc). And ideally you'd be looking to reduce such usage, as it is largely wasteful, particularly in the stupid-ole'US-of-A where the corn lobby has organised it so that it's actually primary production corn that is used to make a lot of the ethanol, not by-products and waste, like it is (mostly) elsewhere. So, what I said about needing free-ish energy probably still applies. True synth fuels would be made from H2 and CO2, in a near reversal of the combustion process. In fact, given that the H2 would be split from water first, it actually is a complete reversal of the combustion process. But...energy intensive. The human race burns something like 1 cubic MILE of crude oil, after it has been made into various fuels. Every year. That's a simply stupendous amount of energy. Just assume that the density is 900 kg/m3, and that the calorific value is 45 MJ/kg, then that is 165.9 x10^12 MJ of energy. Or more than 10^19 Joules. You get a maximum of 1 kJ/s per square meter solar radiation falling on the planet's surface, and so if you halve that for daylight, and halve it again for average weather (highly optimistic) and then take ~25% for the very best efficiency of solar panels, then you need about 85.7 billion square metres of solar panels to generate enough electricity to replace that liquid fuel energy consumption. Each panel is about 1m2. That's a rather large number of panels. We also burn about a cubic mile of coal. We also use hydroelectric power. We also use nuclear. We also use a number of other sources, both "renewable" and not. You can kind of ignore the renewable ones (except for hydro, because it will all end up getting subsumed into pumped hydro for storing other renewables, and so it won't be the standalone renewable that it originally was), so we end up needing a multiple of the ground area number that I just arrived at.
    • Corvette thread then? Don't say I didn't predict the future again. "I love the little MX5, I do, but I just want something a little easier to get in/out of, a little more cushy and some power would be nice - I miss the V8 Rumble... I found this clean red C5 for sale recently and..." I'll do you a great deal on the next step, which is one of those but you can fit people in it, too.
    • What about renewable diesel and/or gasoline? I see some projects spinning up like de-oxygenating ethanol to make drop-in compatible bio-gasoline especially in CA. I still think the future is EVs and we should've all gone full throttle on nuclear power after the 1973 oil crisis like France. Despite 15 years of work in CA to reduce the CO2 intensity of generation with renewables our electric grid is still far worse than even "low carbon" nuclear power. ICE is pretty cool when you aren't depending on the stupid thing to be practical and reliable and cheap as possible to get you to work every day. It's kind of like mechanical watches or vacuum tube amps.
    • I just rolled over "my" first 10k km in the MX5 Every time I go anywhere it always ends up in a adventure to look at houses and find some random country roads I've been on leave since early November but unfortunately need to go back to work on 19 January Luckily though I still have a fair chunk of leave left to burn until.... Not that I'm counting 😁
    • These look like S13 wheels.  And Welcome!
