Parts clear out - All items are in good working order & condition unless stated.
GTR injectors (yellow top) X 6 $250 the lot
GTS-T - Series I or II
Air conditioner climate control module $50
Air conditioner pump, condenser, engine bay hoses $85 thelot
Air conditioner cooler $45
Back seat $50
Boost controller (OEM) X 2 - $25 each
Boot linings and floor mat $30 the lot
post-86505-0-34886700-1319541820_thumb.jpg post-86505-0-03563400-1319541859_thumb.jpg
Centre console $70
Coil packs (OEM) $100
Coil pack cover $25
Dash - under/around steering column $25 the lot
Driver's seat, needs repair $50
Exhaust/turbo manifold (OEM) small crack suit welding, needsmachining $35
Gear shift surround $50
Radiator incl. shroud $75
post-86505-0-07243100-1319542200_thumb.jpg post-86505-0-80363900-1319542235_thumb.jpg
Radiator fan incl. clutch X 2 (one with shortened blades) $35 each
post-86505-0-57885400-1319542305_thumb.jpg post-86505-0-37455100-1319542378_thumb.jpg post-86505-0-69475100-1319542578_thumb.jpg
Rear window wiper arm $25
Space saver spare $25
Turbo (RB25det OEM) - 2 x broken fins, suit rebuild/hi flow$100
post-86505-0-03969700-1319542617_thumb.jpg post-86505-0-36312300-1319542656_thumb.jpg
Turbo heat shields $35 both
post-86505-0-36342300-1319542747_thumb.jpg post-86505-0-94409600-1319542798_thumb.jpg
Wheel centre caps off 16" stockies X 3
Series II
Front grille, slight damage to connector $35
post-86505-0-36839100-1319543505_thumb.jpg post-86505-0-16395800-1319543536_thumb.jpg
Headlight (drivers) damaged cover $50
post-86505-0-59206100-1319543026_thumb.jpg post-86505-0-20665100-1319543066_thumb.jpg
All reasonable offers will be considered via PM, SMS or email. I am not trying to fund a trip to the moon, but will let you know if I think you are a tripper :)
Items are in Sydney - west. I can arrange shipping at your expense (pls ask for quote before you commit to buy).
Call or text me on 0414 431 055 (Greg) or PM me on here or email [email protected]
Edited by MrCini
I also have Series2 ? bodykit, will need a tidy up (see photo + the 2 parts from behind wheels back, shown on car) $150 the lot
Edited by MrCini
  • 8 months later...
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
