So which option give you 40 million?!
for final heist? dunno - i ended up using the people that cost the most for 100% sure completion (instead of losing shit like i did in the first heist by cheaping out), and doing the sneaky approach. ended up with ~20mil per character, plenty enough for what i need. i do like the idea though of doing a replay but not doing any of the assassination missions until after the main story if possible - can then spend massive dollars on investments instead of like 100k.
ah wait here we go
  • Hotel Assassination: Invest in BettaPharmaceuticals (BAWSAQ) before the mission. Look for a 40-50% return.
  • Multi-target Assassination: Invest in Debonaire (LCN) before the mission. Look for a 80-90% return. Immediately invest in Redwood (LCN) after selling your Debonaire stock as Redwood will see a 300% increase within days.
  • Vice Assassination: Invest in Fruit (BAWSAQ) before the mission. Look for a 50-60% return.
  • Bus Assassination: Invest in Vapid (BAWSAQ) after the mission. Ignore any graphs or green/red arrows, if the stock value is well below the "low" value, invest. Look for a 80-90% return (I had to die once before there was any change to the stock).
  • Construction Assassination: Invest in GoldCoast (LCN) before the mission. Look for a 80-90% return.
the fifth one on that other list is a random event as you drive up the west coast - dude wants you to get him to the airport and gives you a tip when you drop him off; 30% return on it.
BAWSAQ is the online one but certain stocks affected by in game actions (a la Lester's missions) are affected as such temporarily.
Sped through the main missions on my second run. Finished yesterday.
Did all of Lester's assassinations this evening. Had about 32mil on each character after final heist. Played the stocks as people have said: cpd put up the most concise guide so follow that.
Made Franklin a billionaire (he's my main guy, he owns all the properties), got a bit Lazy with Michael, only did the pre-mission investments for immediate cash in, more than enough for all his cinemas.
and couldn't give a flying f**k about Trevor.
Yeah, I had heaps of trouble at first with Trevor - too much of a psycho, and how he treats people. Had to skip all his cutscenes.
He seems to mellow out to just being weird by the end though, so it was easier to watch.
Gonna have to run through again; can't wait for PC and 1440p and mouse aiming though! Stupid thumbstick. Would give up auto-aim for mouse any day.
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
