I have a set of 740cc Deatschwerks side feed injectors and have had no end of trouble getting them working right.
I have emailed there support people to get this responce regarding lag times:
If the OE latency is displayed as 530us for the OE RB25 ECU, then think using 1300us for our injectors would be way off. The RB25 uses a OE side feed injector with almost the same coil properties as our 740â•˙s. I would suggest trying something in the 700 rang and see if that helps then adjust from there. Our injector would not have anywhere close to more than twice the latency time as the OE injector.
My injector report from them states lag time @14v is 1.3MS(1300us) and here they are telling me it should be closer to 700us
WTF is going on with that?
Is there anywhere in the northern suburbs i can take these injectors to to get a correct report on both flow and lag times?
I have now changed to a VE tuning based ecu and these settings are extremely important to get correct.
It was either really rich everywhere or really lean everywhere when using nistune k value had to be changed quite dramatically a resize injector should only need minor tweek not a 50 difference deatschwerks support didn't give me much confidence after telling me to ignor there report
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
