( S A ) ++ T H E - B I G - A S S - G O I N G - A W A Y - S A L E - S P E C T A C U L A R ++
Grab yo ass a deal, im pissing off so i need cesh to buy party drugs and drugs are expensive.
LOCATED NEAR MITCHAM IN SA, CAN POST (WHEELS) ANYWHERE IN AUS
TYRES
ALL PRICES ARE AS PAIRS
16"
2x 205/55 - Mismatched pair - 50% tread - $40
2x 205/55 - Mismatched pair - 60% tread - $50
2x 205/55 - Nexen - 60% tread - $60
17"
2x 205/50 - Mismatched Pair - 80% tread - $70
2x 215/45 - Mismatched Pair - 60% tread - $60
2x 245/45 - Michelin/Firestone (mismatched pair) - 60% tread - $60
19"
2x 255/30 - Advan Neova AD08 - 60% tread - $110
WHEELS
Info:
Set of Rays Engineering/Volk Racing - Challenge Wheels, Genuine, no copy shit here, white with red inners. (Made in Japan)
Specs:
5x 114.3 Stud Pattern
17x8" +32 -- 235/45 Tyres (60% tread)
17x9" +35 -- 255/40 Tyres (70% tread)
Fit overs big calipers
Condition:
Great condition, a few scratches here and there, but good overall.
Price:
$950
Pics:
http://img541.images...59/img0547m.jpg
Info:
Pair of STERN Wheels (Made in Japan)
Specs:
5 - 114.3 Stud Pattern
Condition:
A few scratches here and there, but good overall.
Price:
$200
Pics:
(one on the left)
http://a2.sphotos.ak...7_6560505_n.jpg
PARTS
WRECKING BOTH R32 and R33's, post in here or PM me what you're after. a few specific parts:
TRUST GREDDY gear knob: $50
DE-CAT (gutted standard cat) suit nissan: $70
R33:
R33 GTR Rear Strut brace (fits all R33's): $90
RB25 S1 AFM: $100
R33 Brakes, uprights and hubs (complete) - $800
R33 front Upper control arms - $70ea
R33 Upper control arms/Traction arms - $50ea
R32
3" Straight Through Exhaust (from dump back) - $250
RB20 AFM: $100
R32 GTR grill: $140
Whiteline 22mm Solid Rear Sway Bar (+links): $150
REINFORCED Rear Subframe - Reinforced and Solid mounted/Lifted(improves strength, rigidity and roll centre) - $200
Front Sway Bar - $40ea
Front Complete upper control arm assembly's including bracket and king pin bearing - $100ea -- PICS PICS
Front Camber Arms - $40ea -- PICS
Rear Traction arms - $35ea -- PICS PICS
Rear Camber arms - $35ea -- PICS
Rear Hub Uprights - $100ea -- PICS PICS
Rear Complete Uprights - $70ea
Rear Toe Rods (non-hicas) - $40ea -- PICS
Door (drivers side), 2door (coupe), silver with few scratches - $50ea
Drive-shafts - $50ea
Stock Clutches, 1 half warn, one fair bit more warn - $30 and $70
Mate, do you have a set of uprights for the R33 GTR? (not sure if R33 GTS and GTR are the same, need to check FAST).
Mike
0432 562 025
  • 1 month later...
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
