Hey guys I have tried searching the internet for an answer to this but have been incapable of finding an answer so here goes, does the 2001 V35 sedan have a vdc button/switch or does it not as i have not seen one in mine (i haven't been trying to hard to find it as to save my 20 inch tyres from certain doom) my sedan is a 300GT as opposed to a 350GT would this be the reason for one not being there??
https://www.sau.com.au/forums/topic/381252-vdc-2001-v35-sedan/
From my recollection the 300GT (and 250GT) did not come with VDC. Only the 350GT-8 and possibly the 350GT 6spd. The 300GT may have traction control only?
Even the Series 2 V35 sedans only featured VDC in the 350GT-8 while the standard auto only had traction control. Little bit strange I thought, along with the decision to make only front airbags standard in the sedans when curtain and sides are standard fare in the coupes. Even the V36 sedans only have front airbags standard which to me is a big turn off for a car costing decent dough
Ah ok, but let me guess... no traction control switch/button is there?? ( also i was just under the impression that VDC was nissans way of saying traction control at the time obviously i was mistaken haha)
Hey guys..
I hav a got a 2001 300GT recently...n i was wondering if it has VDC or not....
also if traction control helps during rain n all...coz recently my car slipped during rain...
If not then can VDC be fitted in my car? to make it more stable?...
there is a switch which says PWR/ /SNOW ...is it of any help?
thanks
Makkks
Edited by Makkks
^I've never heard of VDC being retrofitted. I imagine it would be incredibly complex and expensive if possible. You're talking about sensors on each wheel of the car, ECU programming etc. Probably cheaper to buy a car that has it already...
The snow button is literally for driving in the snow. I believe turning it on changes the engine mapping and power delivery to suit such conditions, although I have read it is certainly not recommendable to turn it on in normal circumstances. Call me boring but I've never had the urge to flick the snow switch in my coupe.
    • I've sent JaseR33 a private message in the hope he gets an email and contacts you
    • I have seen a case where the starter motor shorting against the casing caused a massive voltage drop + so much EMI that it caused all the sensors to spew garbage data at the ECU. Test the battery to make sure it has acceptable CCA/capacity first, I have gotten "brand new" batteries before that couldn't even power a 10W light bulb without dying probably because it sat in a warehouse too long without being charged. Only easy way to diagnose this 100% is put an oscilloscope on the battery and also look at key sensors to see if there's any clues.
    • There's a bunch of smaller shops that don't quite attract Singer money but are still hiring from that same pool of labor. Those are the body shops that you go to when you can't afford a Singer, but your old Porsche needs some serious bodywork. You can't exactly take those cars to the usual insurance body shops. When I say restomod, I mean they'll do something other than 100% OEM/OEM-equivalent aftermarket parts R&R. In the Porsche world this would be stuff like taking a 50k 964, doing a bunch of deferred maintenance/unwinding the nightmares the previous owners did to the car because a lot of people that own these cars tended to be penny wise, pound foolish types, then maybe some relatively simple off the shelf modifications to things like suspension, transmission, engine, headlights, etc. and you've spent 130k USD. When even the worst houses in the poor neighborhoods are worth 1M USD and the nice houses in wealthy neighborhoods are worth 3-10M USD suddenly 130k spent on a 50k car seems cheap.
    • Hoping to get a few ideas to help troubleshoot this issue, I'll try to keep it short.  A mate popped the motor in his 2018 LDV T60 with the 2.8 turbo diesel motor. He swapped it and I was his phone a friend when he got stuck.  The new motor is in, however it won't fire. The battery is literally brand new, when you crank it the volts very quickly (say 2 seconds of cranking) drop to 8 volts and the engine stops turning over. Watching the belts, I'd say they move about 5cm before coming to a stop. We put a booster pack on, no change.  The only potential issue I'm aware of is, when we pulled the motor the grounding strap was still attached. The strap copped a thrashing before we realised what was going on. It looks okay-ish but it's going to be replaced to rule it out.  The main challenge is, I wasn't there for 90% of the work. This is his first time doing any major work on a car and he was learning as he was going. He thinks everything has been put back together properly, however I'm not entirely confident that this is the case.  It would be good to get some ideas about what else to check. The car isn't spitting any codes so that doesn't help.  I've attached a photo, because why not lol.
    • I mean an N1 came with a minimal paint thickness compared to dealer models. It’s probably had a ton of vinyls and stuff possible a race paintjob or two over the years. you don’t buy an N1 for its stunning good looks or comfort 🤣 you buy it to send it and measure how much air you can get on the hill at Bathurst
