Hey guys I have searched but can only find how to on rb26 valley covers which I believe are not plastic correct me if I'm wrong but i have my valley cover off of my rb25 and I'm wanting to paint it red while it's off. Now I don't want to leave it off as it's only a street car but does anyone how to do it. Do I use plastic primer then use heat proof paint
https://www.sau.com.au/forums/topic/381265-how-to-paint-valley-cover/
yeah plastic primer then paint, should be fine but that could all depend how hot your engine is getting..
for daily street duties and the occasional fang it should be ok, on a track it may not last but hey its only paint..can always rub it back and coat it again....I painted mine in wrinkle coat and its still ok..
i painted my airbox in 2$ not heat proof paint, its been on there for a while and its never peeled either..
It was ages ago when I was trying the same thing and couldn't get the metalcast to take. So to keep the little plug bracket thingy at the back of the cover I just hacksawed a length off the back of an old one so I could still mount the bracket.
Plus did it for a mate who wanted to get rid of a heat problem. And for another mate who wanted vents.
Still have the bits somewhere.
http://www.duplicolo...ucts/metalCast/
^^^This could be interesting.
I am going to do this soon myself but was going to use Gloss Red Caliper Paint. hmmmmm...options...
I even bought a spare cover incase I'm not happy with the end result. See how it goes. :thumbsup:
Edited by Not a Pulsar
Metalcast looks good, but is does sometimes fade and go a little off colour over time.
I did a heap of stuff in the red and it held up for a few years quite well,
I'll post up some pics when I get on the computer.
It's a two stage process of a silver base coat then a candy colour on top. Gives whatever you are painting an anodized look.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
