  • 9 months later...
I am going to do this soon myself but was going to use Gloss Red Caliper Paint. hmmmmm...options...
I even bought a spare cover incase I'm not happy with the end result. See how it goes. :thumbsup:
I did get around to doing this, used plastic primer and caliper paint. Gently peeled off the badge and reattached with fresh double sided tape.
I only just put it on so I guess time will tell how it holds up.
  • 4 weeks later...
you can use normal automotive basecoat and clear, the heat will not affect it.
think about how hot a panel gets in the middle of summer out in the sun? the paint doesnt peel off then, so it wont on the bay either.
rub the cover with 800 wet paper.
wash it with soapy water to remove all rubbing residue and sludge.
clean with prepsol/wax and grease remover.
apply plastic primer, but apply fine coats, not heavy coats, as this can cause imperfections in the paint.
apply paint within 15 minutes of applying plastic primer.
good luck!
  • 2 years later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
