I have my r32 gtst
With rb25det wolf 3d v4 ecu
No afm ect
Pob is
Car has been fine for 2 years or more then started stoping like it was runing out of fuel.
Keep this up for few days then just stoped and have not gone in 2 months!.
I have so far Swaped over crank angle sensor.
It had a big alarm that has been fully takin out. Still same.
Looked cleaned all earths even moved to better spot.
On ecu it's saying it's not sparking or spaying fuel in.
Coil pack are new spilt fire ones
Any ideas will be the best.
Oh it's a s2 motor as well wiring was done buy auto elc when 1st done not that somthing can't be up shit now
It
https://www.sau.com.au/forums/topic/381267-need-help-pls-no-spark-or-fuel/
You'll need to actually make sure the injectors or coils are not firing, don't trust the ECU to give you that information
If you are cranking and see an RPM signal in the ECU software then the CAS should be fine. If you don't see RPM, then you need to check for 12V at the CAS, if it has 12V there, then check the signal wires for continuity and also signal back to the ECU.
Use a noid light to check injector pulse and there are a number of threads on here explaining how to do spark checks but a HEI spark tester works well.
If you have a CAS signal and RPM, then you need to check power to injectors and coils.
Start with all that
Ideas... Ok... A fuse or 2, fuel pump, fuseable link, corrosion, fuel filter, plugs, map sensor, battery is dead or dying, relay, ecu wiring/connection, wiring from alarm removal not correct, dodgy sensor somewhere, ecu has died, corroded plug connections anywhere, water in the fuel. Just some ideas. Look at what you need to make it run and start testing and checking. A gradual death will point to some things more than others.
All the best mate.
  • 4 years later...
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
