hey all,
I'm advertising my Nissan A31 Cefiro for sale, I'm keen to head back to japan again so need all the money I can get!
details are as follows:
EXTERIOR
CA31 Chassis - July 1989 build
Manual conversion
M-sports 30mm flared and vented front guards - genuine
Weather Sheilds
Rear guards flared by 20mm
Genuine Autech Side Skirts
Unknown add on rear bar (Autech style)
Chrome late model grill
Roof wing
Full respray in factory Diamond Black
Factory Sunroof
Late model tail lights
Kaixon 6000k HID Headlight kit
Legal tint.
ENGINE
RB20DET
Nisstune 170kw @ 12psi
R33 S2 Turbo
Xtreme Chrome Moly 5.5 flywheel
Xtreme 9 Puck 25% over standard clutch
SplitFire coilpack kit
R32 GTR coilpack loom
Gutted cat
East Bear GTR cooler kit & piping
Custom stainless intake cross pipe (by C-Red tuning)
R33 GTR VSpec Intercooler (painted black)
Trust 10 row Oil cooler w/ braided lines & spin on adaptor (painted black)
Bosch 040 fuel pump with source power direct from battery
New rocker cover gasket
New Nissan steel exhaust header gasket w/new Nissan studs and brass nuts.
Quality blue silicon used on all joins bends
Silicon vacuum hoses
Silicon radiator hoses
Razor grounding kit
Oil catch can
SUSP. + DRIVELINE
r33 N/A diff (4:3 ratio)
Full 5 stud conversion, R32 Rear & Custom billet front hubs
S14 Steering Rack & custom power steering lines
Powered by Maxx solid subframe mounts, with Barney Custom spacers
Tien rear coilovers and lowered springs front.
VSKF 18x8.5 + 28 front rims and crazy jdm 19x10 + 28's on the rear with brand new 245s.
INTERIOR
Dash matt
6 point "achieve" bolt in cage (not installed)
Greddy boost guage
stock clean interior
(possibly comes with a nardi wheel and sparco quick release boss kit)
(possibly comes with Enon double-din DVD headunit)
the car is registered until march next year but will NOT come with a RWC. however I can organize one for a few hundred extra.
issues with the car:
- gearbox is noisy, bought a box which I was assured was in good condition which was somewhat true.. just noisy (selects and holds gears fine)
- interior fan possibly blocked and not working.
- rear qtr's both have dints though carrying a jack in the boot which moved around.
- drivers door is dinted due to being reversed into by a towball.
- rear passenger qtr panel has been poorly repaired by a previous owner then can spraypainted over.
with a bit of TLC, this car has awesome potential! I'd personally love to keep it and put a 25 in, but being a student.. my budget doesn't accommodate for my dreams! haha
PRICE $7,000ono
can negotiate a much lower price with the removal of 5 stud, rims, cage etcc..
contact Leigh on
0418-221-075.
cheers!
once upon a time this was the stanceworks cefiro - here's a link to it in its former glory.
http://www.nissansil...howtopic=449749
https://www.sau.com.au/forums/topic/381287-a31-cefiro/
    • You’re all still going on about track cars, he has said multiple times doesn’t intend to take it to the track,  just stick to what was said at the beginning and do the pump and ecu, it’ll get you enough for 230kw at the wheels and has enough poke to be fun for what you want it for
    • All of that is absolutely true. At any time in the history of these turbos the lottery has always been that it could die at stock boost treated exactly as the factory intended, or it could die when pushed to 10, or 12, or 14, or 16 psi, after a short time, or a longer time, or it could last seemingly forever. You have the combination of all the possible statistical (probably) normal distributions of manufacturing tolerances and quality outcomes, on top of the statistical distributions of failure modes (which might be normal, but are probably biased, like Poisson distributions). You get the lucky turbo and you can beat on it for years. You get the really unlucky turbo and it will crap itself as it rolls out of the factory gate. And every possibility in between. But you can definitely still kill the lucky turbo. It's just that most people didn't try, once they knew they really shouldn't try.
    • Maybe I have Stockholm syndrome but working on an M2 isn't that hard. Getting parts cheaply and quickly is hard, but getting parts same day isn't necessarily hard if you're willing to pay way too much for it at local dealers. There's a lot going on, you need to have a build of ISTA on a laptop and the right cable, if you don't have the mindset of "do it exactly right or not at all" you will probably start seeing cascading failures. Skylines are a little more tolerant in that regard. The car doesn't potentially trash itself if you bought the wrong oil filter like a BMW would. Or trash the entire cylinder head and potentially spin a bearing because someone took the anti-drainback valve out of the plastic oil filter cap. An M2 will also do just fine on track, zero oil starvation concerns, factory brakes are great if you change the pads for a high temp compound + flush with track-ready fluid.
    • The "ideal/formula" that used to be touted was death of the turbo is going to be caused by a combination of 3 things. Heat Speed of turbo (boost level you're pushing) Time   Basically, you can get away with high heat and high boost for short periods. But start doing long hard pulls, or circuit driving etc, and now you've increased time as well which will shred things. From memory when Adrian was drag racing he was running 17psi, on a stock turbo, and running insane speeds. But he also had other additives helping in the setup too. Some people have success at 14psi for a while, while others due to pushing the cars hard for long periods opt down to lower temps. But also, generate a lot of heat (let's say bad tune), for a long time, and you'll be okay, until you try to spin that little guy up slightly. It's the one advantage of dumping a lot of fuel in, you'll be reducing EGT a bit and helping with the heat portion of the above 3 areas.   And these days, stock turbos are that old that there's the possibility of just outright failures due to material age. I'm not shocked that even when used in factory spec that a stock turbo fails when 30 years old. It's a worn out "precision" "balanced" performance item, that's likely no longer precise, or well balanced
    • this... hence I said what I said previously, SMSP nights you see mainly Hondas, Evos, A90s, F80x and the odd VW. The 5 or 6 times I went, I only saw 1x R32 GT-R, and other than that I was the only one in a shit box Skyline.
