Car has been sprayed satin black and has a full geniune do luck kit to go with the wide body I have also started putting together a stock gtr kit for it so far just the front bar and rear bar with the wing. Looks clean with the gtr kit on.
car needs seat and harness to hit the track
Well Setup
1992 R32 GTST, done 110 *** kms, midnight blue, M-Spec (bigger brakes from factory, better seat fabrics)
RB20DET
Standard internals
HKS 600cc injectors
HKS SSQ BOV / Genuine HKS Purple fin also
HKS Mushroom filter
Custom intake pipe
Z32 AFM
Apexi RX6 high mount turbo kit,
Greddy/Trust steam pipe hi mount manifold
Greddy/Trust 48mm wastegate
Blitz SBC Dual Solinoid Boost Control+ Turbotech Boost Tee
Hybrid FMIC
Exedy Heavy Duty Cushion Button Clutch
Apexi ECV
always had motul turbolite 4100 oil, always changed after every track day or 3000kms
either genuine nissan oil filter or DRiFT magnetic oil filter
Standard RB20det ECU remapped with NissTune by Garage 7, made 254.5rwkw and 408.6 NM on 15.5 psi (yea it actually did)
With Cams and camgears and more boost this rb20det will be capable of close to 300rwkws on E85
Bodywork
Genuine Do Luck GTST T2 bodykit from japan
D-Max 25mm front guards
Carbon canards on front bar
Genuine GTR grill
Genuine GTR bonnet with bonnet vent
30mm rear wide bolt on guards
Silk road vented headlight
carbon fibre roof wing
Interior
Safety 21 7 point cage+ Tabs for side intrusion
Greddy Boost Gauge
Trust Grex Diamond gear knob
Drift Buton
Stock 32 GTS Seats
Stock silvia steering wheel
Suspension
Kei office coilovers, damper, height and spring adjustable, go nice and low
Zenith Solid Steering Shaft Spacer
JJR 30mm Front And Rear Sway bars.
R33 GTR Swaybar End Links
Strengthend Radiator Support for track days via HKS Drift Chain from SA previous ownerGK Tech 5mm Steering Lock Spacers
CUSCO Strengthened Muffler Ring
JIC rear camber arms
Cusco front camber arms
Kazama castor rods
Super Pro nolathane rear cradle mount
A31 non hicas cradle
S14 steering rack
complete hicas removal
Spare R32 GTR Rotors Cross Drilled
Rolling On
Advan 17x8 and 17x9 tri spokes
Pair of modena 17x8.5 +15
Vehicle is located in SE Suburbs, VIC
Item is listed on ebay with pics
http://cgi.ebay.com....#ht_1170wt_1115
Price
Six Thousand Dollars
$6000
Not parting out
Contact Nick-0410217375
https://www.sau.com.au/forums/topic/381288-r32-skyline-gtst-track-car/
