Nissan 350Z Track Model 2003
6speed
35,000kms
Tuned with Motec to achieve 8200rpm
Performance Modifications:
- Engine Internals:
o Nizpro Spec 11.5:1 Forged Pistons (By Special Piston Services)
 0.008” overbore
 Moly coated piston skirts
o Nissan 0.2mm overbore piston rings
o Carrillo A-bean (I-bean) ultra lightweight connecting rods
o Carrillo connecting rod bolts
o Balanced short block
o Over bore and hone 6 cylinder strainer plate
o Nizpro modified bearings
o Nizpro modified oil routes
o Nizpro modified cylinder heads
o Nizpro modified combustion chambers
o Nizpro modified injectors
o Nismo Spec 1 Intake Camshaft (276 degree, 11.0mm lift)
o Nismo Spec 1 Exhaust Camshaft (256 degrees, 10.5mm lift)
o Nismo VTC Pulleys (55 degrees)
o Nismo Oil Pump
o Ferrea competition plus light weight intake valves
o Ferrea competition plus light weight exhaust valves
o Ferrea titanium retainers – 6 degrees
o Ferrea dual valve springs
o Ferrea steel valve locks
o Ferrea valve seals
o Ferrea valve seat locators for Ferrea valve guides
o Ferrea copper exhaust valve guides
o Ferrea manganese bronze intake valve guides
- Intakes:
o Nizpro 84mm intake pipe with integrated MAF sensor to Nismo specifications.
o Nizpro spec larger bell mouth intake integrated in the stock airbox
o K&N high flow replacement filter
o ’05 350Z lower plenum (with shorter runners and larger intakes)
o Motordyne Engineering 5/16” Plenum Spacer
o US Spec 350z larger intake airbox duct
- Exhaust:
o Fujitsubo SuperEx stainless steel header set
o Nizpro 3” high flow catalyst converters
o Nizpro Spec Y-pipe with larger collectors
o Nismo RS concept titanium centre pipe
o Nismo RS concept titanium (with a Z logo) rear muffler
- Drive Train:
o Nismo light weight flywheel
o Fluidampr silicone fluid harmonic damper
- Engine Management System (ECU)
o MoTeC M600 ECU
o MoTeC Cam Control Module
o Nizpro Plug & Play MoTeC wiring loom for 350Z
o Redline and fuel cut: 8000/8200 rpm
- Engine cooling:
o Nismo 11 cores front mount oil cooler system
o Motordyne iso-thermal throttle body coolant controller
o Motordyne iso-thermal lower plenum gasket
o Nismo Fuel cap
- Traction Control:
o Traction Control kill switch (disable factory traction control completely)
- Others
o NGK platinum spark plugs
o Apexi earthing kit
Exterior Modifications:
- Body Kit:
o Nismo version N1 Version II front bumper (JDM)
o Nismo Canards
o Bonnet Bulge upgraded 07+ (Aggressive look)
o Topstage side skirts (JDM)
o Nismo rear under pods (JDM)
o Nismo version rear spoiler (JDM)
o Nismo Carbon Fibre B-Pillar Trims
- Wheels:
o Nismo LM GT4 front wheels (8.5J x 18”)
o Nismo LM GT4 rear wheels (9.5J x 18”)
o Pirelli P-Zero Nero front tyres (245/40/18)
o Pirelli P-Zero Nero rear tyres (285/40/18)
- Suspensions:
o Tein Super Street Height Adjustable Coilover kit.
Interior Modifications:
o Alpine Headunit with Customised CarPC with SatNAV
o Nismo Floor Mats
o Nismo 8000rpm/320km/hr tachometer
o Nismo GT titanium gear knob
Brake:
o Hawk HPS front pads
o Ferodo DS2500 rear pads
o DBA 4000 slotted disc brakes front and rear
o Motul RBF600 brake fluid
o OEM 350z Track Brembo Calipers
$35,990ono
Willing to send interstate also under buyers expense.
0433 759 695
https://www.sau.com.au/forums/topic/381306-nismo-350z/
  • 3 weeks later...
