So I have pal to ntsc converter (when a pal ps3 is hooked to the screen its black and white/wrong etc), a 1000w inverter and a spare ps3 (missus won in a competition). I was thinking for long drives etc for mates to watch vids/play games etc with 120gb of video/audio it would be the goods......So I hooked it all up in the back (above the spare wheel in that compartment) and I get a screen flicker thats quite bad (audio is fine). I have old thick gauge wirring that was to an amp in the back straight powered to the inverter and have tried hooking it straight from the battery (20 cm leads) to eliminate the wirring side of things.
Thought it must be interference with the inverter, so hooked up an extension cord to mains power and I still get the flicker :blink: .
When I have my creative mp4 player hooked up to the screen I have no issues at all (no flicker etc) video is ok......
So has anyone had a ps3/xbox or what ever hooked up to there M35 screen? Or has anyone had screen flicker issues with there M35?
I havent played around with it for long and my searches on the net don't come up with any solid info, any ideas from the electronics gurus on here?
Edited by MOUTH
https://www.sau.com.au/forums/topic/381328-m35-screen-flicker/
i get flicker on the WD Live media player. but didnt with the new asuka tv tuner
there is probably interference in the car, use sheilded coaxial cabling.........
Hey mate I take it you were using an inverter to use the wd player? Last night I tried a xbox360 and ps2 all the same...... and then tried another screen I had laying around and it was fine. So its something to do with the factory screen and some interference between with ps3/pal to ntsc convertor and and the screen.
Edited by MOUTH
I remembered my screen use to get a bit of green waves and loose colour when then Vpp is to high. The screen likes a peak to peak voltage of about 1 volt. So if you measure the RCA plug from the shileld to the core on DC it should be around 1 volt when turned on.
I had a device that put out 2-3 volts peak to peak and the screen didnt like it.
In the specifications for the PS3 it should tell you the Vpp
Or I agree with the possible Hz difference between PAL and NTSC but saying that I would think the converter would sort that out otherwise its not really converting PAL to NTSC
Was the other screen you tried a NTSC or PAL screen and did you have the converter when you used the other screen if so it cant be the converter.
If you get really stuck you can bring it out and Ill have a look
cheers brad will check it out
dude, why are you using a PAL to NTSC converter?
the PS3 will output NTSC from the composite video cables......
Tried this in the first place, black and white and screen flicker, with the convertor I get color.........and screen flicker....On the ps3 website it also says PAL for composite output (obviously if your in a pal region)
http://manuals.plays...ideooutput.html
Now reading this also I have just seen that it will only out put 576i through Pal composite..... whats the max that our ntsc screens do? 480i? Then this maybe the problem?
Edited by MOUTH
its not even 480! its analogue. with the 'Leon' tuner i got a perfect picture on the 576i/p setting, the 480p setting wasnt quite right.
just muck around with the PS3, i swear i can change mine to NTSC in the setup menu - of the PS3
Sorry didn't even think about the digital-analog (480etc).........:unsure:
99.9% sure I cant change it to ntsc
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
