Ok so im having some issues with me new engine.
got a reco cammed rb30 put in, needed to use a few parts off my old engine.
- Lifters
- Whole Intake System
- Whole Fuel System (rails, plugs injectors etc)
- flywheel.
- wiring, ecu, trans, clutch etc were left intact while engine was replaced (not replaced)
1st Issue: this engine knocks exactly like my last one although not quite as bad (happens anywhere between 1500 and 3200 approx rpm), this engine has a mild stage 2 cam in it.......it is currently usuing the lifters out of my other standard cam engine...same problem, i am almost adiment this issue is lifters but i need advice on what lifters to get because i dont know the cam specs.
Youtube link:
www.youtube.com/watch?v=DvmlchfBaE0
2ND ISSUE; When the car gets to normal operating temps (anything over a quarter on the gauge) it randomly starts misifring as if the engine cuts out completely for a minute amount of a second......doesn't do it when its cold, only when it is getting warm, few people have told me Crank Angle Sensor but i'm not sure...
Cheers in advance guys.
Edited by SPINR31
https://www.sau.com.au/forums/topic/381332-r31-rb30e-need-help-asap/
  On 30/10/2011 at 2:00 AM, fat_rb25 said:
if it was the lifters it wouldnt be making a knocking noise just a tapping noise, have u checked ur valve clearence?
who rebuildt your motor? did they change big and main bearings?
it was a mate that rebuilt it, all the bearings were NOT changed at all, he im not sure if he checked valve clearance
i had a higher than standard lift/duration cam fitted to my R31 RB30E head, . . .not 100% sure as to why BUT the lifter cradles HAD to be machined to suit that cam, if you havnt had that done then that could be your problem
the thing is the motor was knocking before you rebuilt it, and now its still knocking and you didnt change ur bearings. so i reckon could be a bottom end knocking
i dont know if you can change the bearings while the motor is still in, if you have enough room to take the sump out and change the bearings
nah this is a different motor to my old one that was knocking, it was knocking the same though with the new motor, which leads me to believe that it is the lifters, or rockers as they are the only bits from my old engine.
yer i have heard that to but i dont know the specs for the cam so i dont know how much needs to be machines off the lifter blocks
  On 31/10/2011 at 10:25 PM, niZmO_Man said:
2nd issue - Crank Angle Sensor
yer cheers, i thought it may have been, do you know if vl and r31 CAS are the same? i read somewhere that the vl use hitachi ones and the r31 use mitsubishi? but does it matter :)
General rule of thumb is ...
If it plugs in it "should work" but either way they should be the same
pull the cam out and take it to a cam grinder and they will have the means of measuring the lift and duration of your cam, from there you can work out if/how much you need to machine off the lifter cradle
be aware that using old lifters is fraught with problems, if they arent matched up to the lobe that they were running on before then they can be noisy, always use new lifters with a new cam and buy good quality lifters, i made the mistake of getting cheap ones and the effing things didnt fit nicely in the lifter cradle
yer i was going to take it to wade cams in melbourne, having said that who does lifter cradle machining, closest to bendigo
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 馃槀 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
