  • Replies 886
Can you confirm a couple of things...
When you pressure test the system, u remove the afm and put in ur test fitting. That means ur intake pipe is in the pressure system, yet has non pressure areas being compressed. Ie your bov pipe and presumably the breather hoses that go from the ex rocker to the intake pipe, yes?
To rule that out please do the test on the system post turbo instead of pre, and make sure ur motor is on TDC. Then work ur way thru to see where its leaking, work forwards... So from there go to ur cooler entry, cooler exit, crossover pipe, throttle body. Work forward until u track how far the leak is into the system.
Ur breather shouldn't need ur finger put over the gromit, that means ur pressurizing ur sump... Obviously from the ex rocker breather via the intake. Otherwise ur PVC is ficked too. Test this before anything else.. Then test the guys infinite boost (blocked actuator) theory and see if it can actually make that boost up high when it cant possibly bleed it off.. If it can do it then u know the issue is boost control (actuator/wastegate arrangement).
Report back and well all help from there.
Yes that's how I've always done it, it did blow my intake pipe off once, took 2 hours to get it all back on and ready to test again. My bov does have a tiny little leak on the outlet side between the bov and the pipe adapter, not a problem during running. I no longer have the pipe that goes to the intake pipe from the tappet cover, that's the pipe I put my finger in. You can see it in the photos.
it will make over 20psi at 6500rpm, hard to hold it steady there without going stupidly fast. so i crept up to 6500rpm at between 15 and 20 psi then i put my foot down a bit quicker to see if it would make 25. not sure if this is a deffinative answer but makes me feel better. so new actuator and new tune and my car should be fine, hopefully the heat soak issue will be resolved with the tune. thanks everyone.
whats running to your p/s pump if your using that as a boost source?
is the p/s side blocked off?
did you use new hose for your boost to wastegate feed? one of the factory lines has restrictors in it
DVS can you pm me a prIce on a retune please.
Thought i did buddy, ill send u another one.
Let me know how u go with the new actuator, more preload, and put the boost source for the actuator in the cooler pipe just out of the turbo.
How long ago in that HG thread did I say it was the actuator lol.
This IS a definitive answer. Your car made more boost at points it never could when you eliminated the actuator from the equation. Done and done. Get that new bitch on her and enjoy.
Sarge. I did believe you but I didn't have a safe way to test it, that's where my wife comes in handy.
There isn't any boost feed going to the ps pump, I used new vacuum line to the turbo.
Yer I deleted it by accident and couldn't remember what you said.
That's the vacuum valve on a neo rb25. That's what I took the line off, il trace the other line and see if it's causing a leak.
Edited by lilcrash
I thought the Hypergear turbos had a nipple on the outlet of the turbo already for that purpose...
If not, do as Jez has said and put a brand new nipple on the intercooler pipe, nice and close to the turbo.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
