Crans - the strange part is even if I don't have the afm connected to the intake just plugged in electronically it still misses, il try to resolder it tonight. Hopefully it works.
I installed my catch can today so hopefully that's one problem fixed
  • Replies 886
The catch can is hooked into the intake. Don't think it's advisable to just let it drop on the road.
It actually runs very very well, if that's limp mode I don't want to fix it. Then my wife's car will deffinately be quicker then mine.
Ok so how many people reading my thread have hypergear turbos? How many psi does your turbo loose from peak to redline? From what I have read hypergear turbos are supposed to have a boost creep behavior not a boost bleed off behavior. Am I just over thinking it?
You need to sort out all of your other issues before you start asking these kinds of questions. When it's all fixed and tuned (with new actuator ) these questions can be accurately answered.
This.
I hold 19psi rock solid from 3500ish to redline. Creeps a little bit to about 19.5 at around 5000rpm. But until you've sorted out all your other issues, forget about comparing your setup to others.
Yours is losing too much boost. Your losing around 8psi from memory, too much.
5psi would be the maximum I would expect if I was running 22/23.. I wouldnt want it to drop under 17psi by redline.
With the old actuator I was dropping from 20 to 14, new actuator I'm dropping from 25 to 20.
All my issues are resolved apart from the boost drop, but I don't think that is fixable, I'm planning on getting it tuned to suit the current boost curve and see what happens. Was just curious how much boost everyone else is loosing.
I now have 3 actuators. 7psi creep up to 16psi, 22psi drop to 14psi and 25psi drop to 20psi
There is an allen key near the WG flapper.
That adjusts the WG creep... Ask Stao for a 101 tut on using it. With everything else uve tried I doubt you will finally blow it doing this one.
i'll be back up in qld by the end of the week
i can come look at it all for you
do you still have the stock actuator? from what i can gather hypergear's housings are a little longer than stock, i've been thinking about cutting the actuator rod, tapping both ends and putting a long "nut" in between the cut pieces, a bit like a hks actuator
it seems that hypergear's actuators are a bit hit and miss, but 99% of stock ones work fine, but have weaker springs
you could also do that to an rb20 one (10psi spring)
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
