Ok, I thought it would be a good idea but just confirming things. This is my first Nissan rebuild so parts that are actually easy to buy is new to me.
I can only find 3 pumps, n1, tomei and nitto. I'm pretty sure that the tomei and nitto would be over kill, but what about the n1. Is it too big too?
  • Replies 886
For future reference. The valves listed in the ferea catalogue are different to the Nissan valves. My machinist ordered one in to replace my worn out one and it didnt have the step down for the retainers, $45 was what he paid for it. Nissan are supplying me with a genuine one for $34.
The machinist was going to replace one valve yes. I didnt realize it was a different sort of valve, I never saw it. The ferea was the only one he could find for the 25neo.
Yep. Also know the feeling of trying to work out a problem that seems so simple to others, and yet in the end has nothing to do with what anyone said. Chocco, not everyone here is an expert on cars, give the guy a break.
Lilcrash, sorry if I missed it mate, but have you explained how you have your breathers plumbed in? I'm assuming you're using a catch can and it's not just the stock setup yeh?
Like when my car wouldn't start, I tried everything then suggested broken camshaft, everyone lold and said no way, in the end it was an broken camshaft haha.
Just read all this thread, when you finally get it running again promise you won't run more than 10psi without getting it to a tuner first, get the tuner to strip out timing and make it ridiculously rich, even up in the load cells you aren't close to touching. Then go play with the actuators and get the right boost, once you have the right boost take it back and get it tuned at that boost.
Remember if you change nothing you will blow the new motor up just as fast, the issue wasn't with the motor, it was with everything else.
Should save a repeat incident. Good luck with it all. :)
Edited by Rolls
I'm still confused as to what went wrong but yeah I am putting the smallest actuator I have here on I think it's about 7psi, depending on if I run it in on the road or on the dyno it will go straight to the dyno for run in or straight to the dyno after run in. I will get it looked over, dyno checked at 7psi and once I'm sure nothing is faulty I will put the original 20psi actuator ( that dropped to 14psi ) on and see what happens. hopefully It will hold 18psi to redline. If not il just put the 7psi on and turn it up to 1 bar and leave it.
Just for future reference, problems I've found so far - head gasket pealing apart, loose exhaust manifold nut( cause for the noise? ), inlet valve number 9 was about to drop as the retainer/valve stem area was worn and worn out rings in cyl 1
You ran 25psi without a tune, that is what went wrong. Even 20psi when tuned for 15psi will almost certainly detonate. I remember telling you in the hypergear thread months ago not to do this, all it takes is 10 seconds of sustained detonation and pop goes your motor is the result the majority of the time.
Don't do anything and see what happens, get it on a dyno first thing and do not boost it even once. Get the tune right, then play with things WHILST on the dyno. If you don't I can guarantee you will blow up your new motor.
Please DO NOT put the 20psi actuator on without being on the dyno. All your problems that you listed are caused by detonation.
Edited by Rolls
yeah i meant i would be doing all the stuffing around while on the dyno. if its all caused by detonation then there is my answer, i didnt realize detonation could wear out rings. but it is good to know that the tune is to blame. so thanx *** *********** for all the problems you have caused, apart from the oil pouring out which was caused by the rings dieing due to prolonged detonation im guessing. that same detonation sound could be heard from the second i picked up my car, thats half the reason i called them 10 minutes after i picked it up, and never got a call back.
oh well new motor and new tuner, lets hope it all goes well.
I was on here asking questions about it when all hell broke lose in the first place.
I was never intending to make that much boost, I didn't really think the new actuator was that much bigger then my old one. Neither of the other actuators make the boost they are specified as so yeah stao said 22/23. I thought oh yeah 18/19.
Edited by lilcrash
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
