  • Replies 886
yeah i meant i would be doing all the stuffing around while on the dyno. if its all caused by detonation then there is my answer, i didnt realize detonation could wear out rings. but it is good to know that the tune is to blame. so thanx *** *********** for all the problems you have caused, apart from the oil pouring out which was caused by the rings dieing due to prolonged detonation im guessing. that same detonation sound could be heard from the second i picked up my car, thats half the reason i called them 10 minutes after i picked it up, and never got a call back.
oh well new motor and new tuner, lets hope it all goes well.
25 psi was the problem not the tune per se. Please understand this FFS. Just a few secs of det at this boost level toasted your motor not 'prolonged det'.
If you go back far enough the issue was setting up boost control on an untuned stock ecu and had moments of uncontrolled boost. Was warned not to do this.
Advised to get engine management asap and to drive the car gently until tuned but he continued to set up boost control with different actuators with an untuned Nistune. There was audible knock while doing this. On more than one occasion.
Then finally took car to EFI for tuning.
IMO the damage was done prior and EFI were left with a sick engine to start with.
i wish i knew if it had been tuned at all, if they did actually tune it, im not sure if they actually did now that i think about it but thats not for discussion at this current moment, i would assume it was tuned with the 20psi dropping to 14 psi.
im sorry i that didnt realize that even boost cut was too high for engine to run at for the split second my hit it oh wait that has been happening for 3 years with the stock turbo.
Yes, meaning it wasn't tuned for 20psi in the correct load cells. You put more load on the engine and add more boost without tuning for it then of course it's going to detonate.
I don't get your comment about the TP cut. If you increase the boost at all over factory then there is a chance it will detonate. This is why you get your AFR's checked when you do modifications like that, you don't just let it hit TP cut for 3 years thinking that means it is safe :blink:
I only ran the 18psi for a short drive, I thought it had the smaller actuator on, later confirmed that the smaller one was the second one in the box, until I took the car to the dyno I had the 7psi actuator on and wasn't revving past 3500/4000 as that's when it got to 10psi.. I swapped it about 30mins before I got to the dyno and I drove very sedately for those 20km.
And no I didn't have any audible knock as that only hit at 6000ish rpm. That all started on the way home, that's why I was concerned.
The boost cut issue wasn't something I tried to make happen, it normally made 11/12 psi. On cold mornings it would spike ocasionally without warning.
And before this gets turned against me too, yes every time it happened I turned it down a bit more.
Edited by lilcrash
I'm not sure, the machinist hasn't touched the block yet. I've had to put it off until I have more cash. Christmas has emptied my pockets. But with any luck I should have it back on the road and fully tuned for my birthday in march. If I decide to keep it. I'm wondering if someone would be interested in buying it before i even turn the key. :/
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
