  • Replies 886
At a guess $500 at a minimum for shipping. So I could just assume $3500 aud to send it, have it done and send it back.
I didn't really want to pay that much but it's an option if I can't find anything closer.
Why fkn bother when a 200000km 15+year old RB25DET unopen engine can make over 300rwkw and last.. do what everyone else has said and buy a second hand engine replace the timing belt and water pump (100K service) and drop it in. you will have no problems making 240kw for years and most likely blow the turbo before the engine oh not to mention save alot of MONEY!
If you MUST rebuild so you know its like new i would recommend ERD (Elite Racing Developments)
$3500 nzd approx for rips to do it. Plus shipping both ways.
That isn't actually that bad. Most people pay that locally for some hack workshop to do it. Why don't you try ERD or all of the other local ones first?
Or why don't you just buy a neo off here? They come up for sale fairly often if you search every week.
jet r31 can you please pm me some contact details please.
il go to nissan about an oil pump and a set of pistons tomorrow.
il give spot on performance a call tommorow, thanks for the info booztjunkey
Don't buy anything unless you speak to a builder, they will have all their own preferred parts.
Why not just get RIPS to send over a RB30 short motor? Prep your existing head to suit, modify piping and get it engineered.
That is way out of his budget.
Edited by Rolls
Steven you should get a quote from CRD in Brisbane and Paul at Red-R Racing in Newcastle. Tell them to beat RIPS price and go with it.
I had Boostworx here in Adelaide rebuild my Stagea S1 Rb25 for $4200 including forged CP pistons, complete block prep and head clean up.
That was a Tow-in and drive out price, including the dynotune in a months time once Ive reached the 1000km running in mark. They outsourced machining but performed the complete assembly, including engine out/in.
The rebuilt forged bottom end is driving very nicely indeed; only minor issue I have is the fog lights & audio amplifier arnt working but I know they'll fix that up for me considering they were working pre-rebuild.
Once rebuilt find a Good workshop for tuning for a safe & mild tune and stick with them.
Personally Id be leaning towards a budget rebuild but including forged pistons over a used secondhand block, and I wouldnt be going for new genuine pistons when the CP's are cheap brand new on ebay currently. But thats just my opinion.
He needs a need AWD neo for a stagea and they don't come up every day.
NZD$4250 with adapter and pickup is way out of his budget?? Really??
ok there is lots of responses on here il try to do them in order.
r33 eddy - im avoiding using erd (had a great experience with him and a less satisfying experience), but they out source their machining as far as i know or atleast thats what i read on here.
wolverine - i did consider the rb30 and i talked to rips about it but just isnt what i am after. i want to try to keep my vct. if i could keep the vct i probably would have got one already.
rolls - il definately discuss my options with a machinist before purchasing anything.
tangles - crd is in silverwater nsw, im guessing you miss typed erd, as above not wanting to use them. i was looking at cp pistons because i assumed they would be a cheapish opton. im really only looking to do a refresh with new pistons/rings, oil pump and bearings anyway.
dvs - is it an awd block?
wolverine - as above is a good option just no vct opton so :(
Edited by lilcrash
If you use your neo VCT head prepped to suit an RB30 on the relatively low comp RIPS standard bottom end how will you lose VCT? The smaller chamber volume of the neo head will bump up the compression nicely and it will work just the way it does now except with more grunt down low.
    • Can perhaps see how the R33 appreciators would think so.
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
