  • Replies 886
There isn't anything hard about bolting a head on.
famous last words....
or is this the famous last statement "What do you think I'm going to do wrong?"
you basically have ignored every answer you've received, is this a build thread or a question thread???
Just to clear things up. My machinist is doing as follows. Bore/hone/shave the block, install crank collar, remove aluminum plugs and install grub screws in crank, polish/balance crank, install new crank bearings, put pistons on the rods, install pistons/crank into block.
I will get the block back and install the oil pump and water pump, bolt the head and sump on, install the timing belt, install timing cover/can covers. Bolt engine to gearbox and put the whole thing in the car.
Have I missed anything that the machinist should be doing?
Not all of it, I haven't paid for the bearings, grub screwing, crank bush or balancing yet.
It's going straight from my garage to the dyno to make sure my tune is safe enough for the run in. I can't think of anything that could go wrong but who knows anything is possible.
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
