  • Replies 886
ok getting it all balanced as we speak, just a concern, im leaning toward replacing the clutch but im getting it balanced my excedy, will the new clutch affect the balance that much?
Ok just got the call from my machinist. $866 for the balancing, grub screwing the crank, checking bearing clearances, installing crank collar. So my build so far is very close to $5k
i doubt that anyone is still actually going to help me but i have some questions.
my stagea manual is in Japanese, but i have an r33 manual in English (only covers rb26 bottom end) will the rb26 bottm end and rb25 top end torque settings be ok for my rb25 neo?
what is my ring gap supposed to be, i just want to make sure it has all been machined correctly before i assemble it. (cp pistons, 86.5mm)
arp head studs, what kind of socket is it and what size?
assembly lube, is it normally in the oil section at auto stores?
Ok incase anyone cares. I'm going top 17 mid 19 oil 16.
The manual says to stretch the head studs, do arp studs need this done too? Will i need to re tension the head studs after the run in?
Head settings In my manual says
Tighten to 29N-m
Tighten to 98N-m
Loosen to 0N-m
Tighten to 25-34N-m
Tighten to 93-103N-m
But the arp booklet says 80N-m
What should I do?
just noticed something strange, in the paperwork for the pistons it says the rings are made to suit a specific bore size but when measured they came back at top .010 and mid .015
what grade file should i use to file the gap?
Just thought I would try the cp ring gap calculator formula and according to that my ring gaps should be top .018 mid .024 and oil minimum .015.
That's kind of disturbing.
ok update. out of the box the rings measure as follows, #1 - .010 and .020, #2 - .012 and .022, #3 - .011 and .020, #4 - .011 and .020, #5 - .010 and .022, #6 - .011 and .020. ive set all the mid rings to .022 as per cp specs. with any luck i can find a harder file tomorrow and set all my top rings to .018
and yes i realize im probable talking to myself, but im considering this as my blog from now on. that way atleast i can come back and find out what ive done/done wrong
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
