  • Replies 886
Its good to know its possible to do the seal without pulling the pump off. Just a thought. If my front seal is leaking does that mean I need a new timing belt because it will be stuffed?
If you used a fresh timing belt, you don't need a new one. You've done less than 250km on that belt, waste of money changing it. Its not like you change your pulley belts everytime you take one off to get to something else.
Mmmm I don't think car oil has the properties to ruin a timing belt... Its made of material much MUCH tougher than rubber and oil doesn't eat rubber. It should be fine. Someone should confirm this, I don't want to be wrong and then the belt breaks..
Edited by SargeRX8
just to throw it out there - You really don't want a slippery belt on there.
And you must choose your cleaning solution wisely - or the belt WILL deteriorate..
Good to know this stuff. It seems logical to replace a $100 belt than risk a 5k engine.
The leak is very minimal, like there isn't a difference on the dipstick. Just a few drops on the floor. It didn't have leaks hen I did the oil change, but in the next 15km it started to leak :/
It's not the front seal. It looks like its coming from up higher. I can't see where but yeah. Maybe the oil pump bolts aren't tight enough? Is there actually much pressure behind the oil pump? There isn't a single spec of oil vapor in my breathers.
Whos the new workshop to blame now?
Was efi to start with now who?
Name and shame your wonderfull work
What's it to you man? Why is it so important to you that every time something goes wrong with Steven's build, you are there to rub it in his face?
Why is anyone to blame at all. It's an oil leak. And I do still have negative things to say about 2 businesses at yatala, I just know its not worth worrying about it anymore. Proving their lack of quality work won't fix the problems or put the money back in my pocket.
I was actually wondering when you would be back.
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
