I haven't reinstalled the catch can yet. I have to make a new one as my air filer stole its home. But I've been unplugging the hose when I check the oil and there isnt a single spec of oil in it.
Edited by lilcrash
  • Replies 886
Can't believe after all the cost labour and effort youve put into this new engine that your driving it untuned like its a daily...
I honestly thought you would of learnt from killing the last engine
I did have it unhooked only hooked it the other day.
Im not using it like a daily at all. I drove it to work so I could go for a mountain run after work.
If I could find tuner who I trusted it would be booked in, as it sits I'm just slowly putting ks on it waiting for my tuner to move.
Ok I'm going nuts. To me it looks like the oil is coming from above the oil pump. I had it running for over 10minutes without the top timing cover and nothing came out.
How common is it to crack the oil pump? I read it can happen if the crank collar is wrong.
There wasn't a gasket so you just didn't put one on and used sealant?
That's te stupidest thing I've heard.
You my friend, need to take the engine completely out, remove the sump, remove the oil pump, apply a gasket with loctite gasket sealant (red stuff) and then put it all back together.
well im sorry but when my oem gasket kit didnt include one i assumed it just used sealant. later i found out that it hadnt been returned to the kit.
i have a gasket now and obviously i am going to replace it but i just wanted a confirmation as to how many oil pumps had cracked.
Don't apologize to me, apologize to yourself for creating at least 2 days more work, money, and car off the road.
You have a stupidly long thread that many people are subscribed to, and you didn't ask? I though it was common sense that no two metal surfaces that keep in a liquid under pressure go together without a gasket?
I can't see how there is even any pressure in there. It's just the air space in the sump and crank case. My breathers don't have any pressure so how does the oil pump? I can understand if it was the oil pump itself but yeah.
And I did ask people and they said the sealant should hold as its no different to the sump.
lol !!! there should be around 80psi behind that oil pump man !!! not sure what pump u used but did u see the 2 small holes in the back of the pump ? they are diagonally opposite and are your feed to the filter and pick up. the feed to the filter has all the pressure !! after the filter it goes to all bearings on the crank, crank can only bleed off so much oil so then the relief valve opens !!! sht loads of pressure dude.
Unlucky mate one thing i learnt the hard way is NEVER ASSUME ( u no the old saying "when u assume it makes an ass out of u and me ) lol
it's a silly mistake we all make them tho just another learning curve
When is the engine coming out now ?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
