At least now you know its nothing f*Ing up. Fit the gasket and get it tuned, even if its a low boost quick tune somewhere prior to getting it in to your trusted tuner. Bloody important mate, don't just 'wait', get a basic tune done, otherwise you run the risk of ..... Well, you know.
  • Replies 886
Well then stop boosting it past a couple of psi (in my opinion undo the wastegate spring again). Sure, load up the engine but without boost. Detonation is Not your friend. Hitting 16psi isn't the right way about it.
300 km until I switch to normal oil. End of run in period.
I haven't let it get over 3/4psi again. I've been very very careful.
I won't have it off the road long enough to send my ecu to you. And I can't adjust anything without a password can I?
Yeah. That's what I meant.
I think I might just have to put my car into a mechanic to get the oil pump gasket replaced. It's just too big of a job to do it again.
Yeah I just did what a majority of people have done. High load slowly increasing max rpm. Oil change at 100km and 1000km. The oil analysis came back fine.
We dropped the sump just enough to clear the pump, cleaned it up and re sealed it all.
But it all went pear shaped this morning. I went to change the oil pressure sender over and it fell apart. So a mad push bike ride to the train station and now in on the train on my way to being late for work.
Edited by lilcrash
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
