  • Replies 886
Come on. What's your prediction.
I only assumed turbo failure because it stopped making noise and my exhaust got really quite. Zero induction noise.
I'm at a cross road now. My chosen tuner has started working at a workshop that I will never let my tires roll into ever again.
My prediction is that you are going to spend many many more dollars.
Then sell it at a massive loss.
Then buy a corolla wagon.
but the legend will live on for ever on SAU..
"Hey remember that Stagea" they'll say..
and the other one will go "lol.. yeah.. man that was some crazy shit... it was like watching a train wreck"
anyway...
I have no doubt that JEZ knows what he is doing.
But to drive 800km to get a tune is retarded of the highest order.
ESPECIALLY cause you are not willing to get a local person to at least do a quick tune of the cruise area of the map.
Your mindset of not going to EFI/ERD is proper retarded too.
apart from you, not a single person has ever had ANYTHING bad to say about that mob.
and you won't even explain why you won't go back to them apart from say "i had a bad experience..."
did they not print your receipt on recycled paper or something? and therefore are murderers?
anyway, I'm glad this thread is here because it is entertaining to read.
Carry on.
anyway...
Carry on.
Problem is if he does take it there, and his shitty engine build with missing gaskets and only god knows what else, blows up, then he'll blame the tuner.
I'm curious as to how you have come to the conclusion that Efi has never had any other complaints. There is a long list of people who laughed at me for taking my car there, at the end of the day no tuner is going to get it right everyday. My problem wasn't so much with the tune, but the after tune questions. When you have a customer ring within minutes of leaving because things are going wrong, do you ignore it or ring them back when you get a chance? I'm not sure about you but when i get my car tuned then get a check engine light come up I worry.
I understand that you will all have your opinions of my engine build and that's fine.
Im very much past mouthing off about what was done to reduce my view of them and I think it's best left untold.
I agree that a few over boost situations may have weakend my piston and then it cracked under average driving conditions. There is still no answer to my boost problems and I'm hoping that these will be resolved this time it's on the dyno.
Edited by lilcrash
Seriously...
Does this thread need to live after this?
I knew this would happen but oh no a few members have faith.
After reading "oh my turbo stopped making noise" this kid has NO f**kin idea wtf is goin on.
An engine thats held together with hopes and dreams?
f**k me I wanna see this bad boy run 5bar through a stock turbo, might make some wicked sick
numbers.
Just jack it up and floor it in the garage at home and tune it like that I reakon, its about
as good as wat youll get from this build or slap together as Ill call it.
you guys are fucted, seriously...
yep he has made some strange mistakes but he is learning along the way...
I dont necessarily agree with his methods, but its like reading a book, I just dont know what will happen next when I turn the page...
I definitely hope it all turns out well Steven, but yeah more investigation, research & knowledge before jumping in and doing stuff is good advice...
800ks on an untuned freshly built motor, not the most sound logic...
I get the impression that most of you think this is my first car. Precautions were made before I did any excessive driving. Everything in the engine has been double checked. There is the same problem ratio as if anyone else had built it. At the end of the day if it dies its my fault. Things happen. I've made all the precautions I can.
Seriously...
numbers.
I honestly, for the life of me, can NOT figure out what your problem is. Seriously, I wanna know. What's it to you? Why do you care so much? Honestly, I couldn't really care less whether Steven's rebuild works or it doesn't (no offense Steven). It's not my car, why would I? But I still wish him the best of luck with it, and I'll follow along and offer any help or advice that I can because that's just what you do. So why are you so desperate for this to fail? Are you really that narcissistic?
Ok just want an opinion on what actuator I should attempt to use for my tune.
Low pressure - 6/7psi that creeps to 16-18psi with a boost control to try to get a constant 18-20psi
High pressure - 16psi sometimes normally 20psi that drops to 14psi with a boost control to try to hold boost on.
Logically I think the low pressure would be the smart choice but just want a second opinion.
Ok I tested the actuators on the bench,
Mid actuator - starts to move at 2psi, 100% at 28psi
High pressure - starts to move at 20psi, 100% at 50psi
I haven't tested the little one as its on the car.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
    • I just finished up a manual swap and I have a 1999 S2 AWD automatic in my garage, depending on where you are located. I'm in the the midwest of the US.
    • I’ve heard it can be done, you need to redrill the holes where they bolt to the chassis and apart from that they are the same. I’ve never done it or know anyone personally that has, it’s just something I’ve heard
    • If it's reading full rich prior to a misfire that gives one directional hint, if it's already reading lean, etc. If it's reading pretty cleanly stoichiometric then suddenly drops out from a misfire that suggests it's not air mass estimation that's the problem. Could be ignition, could be something more subtle. Could be the CAS has decided to start dropping out at random or the drive pin is worn leading to excessive lash and trigger errors. LTFT can tell you the same but it's slower to react and if this is a recent issue it might not have stabilized. STFT stuck in one direction vs fluctuating back and forth can be used instead but I like to read O2 voltages anyways and interpret directly. If the O2 voltages make no sense in general or are super slow to react it could also be a failing O2 sensor. There's no real error correction for failing O2 sensors in these cars.
