Cant talk atm but i can txt so if u want u can msg me.
I was just going to take a quick look at the tune if u coukd download it but if u cant dont stress.
So just to recap what issue's are u having recently?
  • Replies 886
It pulls then doesn't then it takes off again, like a massive hesitation. I want to try to send the tube I just don't know how nistune wirks
Do you know how to connect your laptop to the ECU via the CONSULT port? Do that, then go to file in NIStune and open your appropriate address file for the Stagea. Then siwtch the car onto IGN, and click the "CONSULT" button at the top right of the screen. Click ok to the dialog box that comes up. Once you've done that, there is a button at the top of the screen that has two arrows on it, from memory one is blue and the other is red. Click on that, then click on the button that says something like "Read data from ECU". The other one will say something about writing data to the ecu, don't click that one. Then go to file again and save the image file somewhere so you can send it to Jez.
I THINK that is all correct, but it's been awhile since I used NIStune. Maybe just get on their website quickly and have a read of the documentation, it's all explained in there.
This thread is epic haha, I have been avoiding it but decided to read start to finish. About 45 minutes later and here we are!
To whoever mentioned getting a scooter and living with that for 6 months while their Skyline was off the road - my R34 has been off the road for over 2 years now and I have not had another car during that whole period, much to my wife's disgust!
I was surviving with a 250cc scooter to begin with, then I bought a new Kawasaki 1400 GTR a little while after. Coincidentally this morning the 312kg GTR fell over and smashed into my Skyline... Not happy :(
Anyway sounds like you have had quite an adventure with your Stagea lilcrash, I bet you have learnt a lot during the whole saga. Sounds like you are getting closer to getting everything sorted once and for all though, hopefully! Good luck with it all. Hopefully mine will give me less drama and I put it all back together.
ok so ive discovered that it only has this problem after i baby the car for a while, if i drive it hard the problem goes away after a few good bursts.
wrong spark plugs/gap??
Edited by lilcrash
Scooter for the win while the skyline is off the road saves heaps of money aswell
I'm back from holidays Thursday pm me and I'll remote in to your laptop take control of your serial port and download your tune for you
Yeah true I got stuck in the big down pore afew weeks ago was not much fun at all
You just need the appropriate wet weather gear. You get used to it when you have to. Although my bike is pretty comfortable in the weather anyway with its electric screen, heated bits etc :P
Stable in 125km/h winds is it? :P
Fark that. I had a scooter when I was 16. Bloody thing would get blown around so badly, I remember driving home from my gf's at 1am, pouring rain, no gloves. Was so cold I couldn't move my fingers to squeeze the brake :/ Good times.
Don't know about 125kmh winds :P But it does feel completely solid on the road even in heavy cross winds, probably because it weighs as much as a tank.
I know what you mean though as even my 185kg 250cc scooter is horrible to ride even in moderate winds.
    • I wouldn't be concerned at all, other than to suggest having them flow tested when you receive them to confirm they are reasonably similar, and then put the highest to lowest flowing ones in cylinder 6,1,5,2,4,3
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
