You got the Neo head, just source a series 2 Na RB30 block, there are plenty around. All your current ecu injectors and ever thing else still works as normal, need a return. The driving ability from the Rb30det to a RB25det is totally different, heaps more torque, plenty of power band and lot faster response.
  • Replies 886
Im not convinced thats metal man.
Whenever Ive had a metallic issue like that the alloy is generally coarser.
Have you checked everything? If that was from the turbo you would have crazy shaft play, easy thing to check and rule out THB. It may be dirt sucked in from when you had the rocker breathers open.
I don't think it's worth worrying about. It just looks dusty. I think the metal may have gone in during the removal. As they are fairly large bits. So far I've got the top half of the plrnnum off and the turbo off and timing cover off, how do I loosen the belt? Is it just springloaded?
Edited by lilcrash
you wont be able to move it side to side...will only lift straight up
as said before there are 3 M6 bolts (10mm heads) 2 at the rear on either side and one on the turbo side front
Massive PITA if you still have the manifolds fitted
there is 2 bolt holes at the rear of the head but there isn't any bolts in them, i un did the bolt from the power steering pump that was into the head but i cant find any more bolts, does anyone have a picture of the bottom of an rb25 neo head? also there is E T written on my intake cam with paint pen.????
ok head is off, apart from the sand in the bores that ended up in there when i lifted the head all looks fine so i guess i just have to keep stripping until i find something wrong.
i find it amusing the stuff nissan stamp into their parts, like my valves all say 5L
definitely a strange question considering all the info you need has been covered before...
Are Rb30's Legal In All States Of Oz?
a man who needs others to do shit for him is a man not able to do shit for himself...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
