There is no way that I will be buying a second hand motor, my wife won't let me waste that much money for more problems.
I trust my machine shop to do a good job.
A second hand motor is guaranteed to be build perfectly with zero issues, it isn't guaranteed to have had a good life, however unless someone has put an aftermarket ECU on it and turbo with bad tuning causing it to detonate, or had oil starvation there is almost zero chance it will fall apart. A great way to get a known motor is to pull one out of a crashed automatic car with stock everything.
A build motor is a complete gamble, has the builder built these motors before? Remember the guys at nissan were spitting out 10 motors a day for years, they were absolute professionals in everyway. If you build a motor how do you know the parts won't have issues, how do you know they will balance it properly, can you trust them to get the tolerances right, can you trust that they will even measure the tolerances?
What about if they bore the block, will the use a torque plate? Will they use a proper torque plate? Was the head they used on the engine warped and machined flat, if so it could crack the camshaft 10,000kms later (mine did). What about preparing all the parts, will they use the correct lube? Will they use plastigauges and check the tolerances a second time when everything is torqued together?
What about simple stuff like installing the rings correctly, they might have done it before but accidents happen.
As you can see there are a 1000 places you can go wrong with building a motor, if the builder/assembler has not done an RB before bail, if the builder has not done 10 RBs before bail, if he has not done one in the last year bail. You want someone who does these engines every month. Do they offer a warranty? If not why don't they? Do they outsource labour to other companies eg machining etc, if the machinist stuffs up and he installs it and the motor dies will he warrant his work or will he tell you it was the machinest fault and not his?
End of the day you should just buy a short block from a reputable workshop like red r racing, racepace etc.
Saying "I trust my machine shop to do a good job." is like going "lalalala" and sticking your head in the sand, you are just hoping they will do a good job, you have no idea if they actually will, they might do the best job they can, but how will this job stack up against nissan? It is more of a gamble than buying a second hand motor, I can guarantee you this. I see more popped rebuilt motors than I see popped stockers.
i under stand fully why buying a 2nd hand motor is a bad option, thats why im not really considering that an option, i could buy an unknown km/condition 2nd hand motor and it might only last a few weeks, id prefer to spend $2000 building a brand new internal motor, keeping my matching numbers block in the car and having it built for alot more power then i will ever make with it. then i will know that nothing is going to break in a few months time.
An unknown condition 2nd hand motor is no differnet to an unknown built motor. Who says the built motor will hold more power? How do you know it will? How do you know it will even hold stock power levels? You don't, you are just guessing.
A stock motor is going to cost you less than half the price and imo has even better chance of lasting, don't buy some random motor, buy something with some history, eg I found an automatic R34 that had been torched, everything was 100% stock and unchanged, even had stock rims and exhaust, pretty good guarantee there.
I bought a $9000 rebuild rb25 with forged everything, the motor was a piece of shit, the camshaft snapped, the thing rattled and leaked oil, everything was loose, wrong gaskets were used, all round it was rubbish, luckily I basically got the engine for free with the car, and to top it off this was a well known performance skyline workshop that built the motor, they just weren't well known for building engines.
Either buy a stock motor with history, or buy a short block with warranty from a proper performance engine builder with a known reputation, anything else is a gamble and I highly do not recommend it.
I can you see where I am coming from here?
Edited by Rolls
  • Replies 886
I see what your saying.
Is there any known rb builders in south east Qld?
I really fail to see what businesses are thinking when they don't have web sites. I wonder if rips will rebuild my bottom end if I send it to them.
Do you expect the builder to do a good job if you are paying $2k for machine work and labour?
In another month you will start the thread "Is it normal for a built motor to be noisy and blow smoke" and then your money pit will be for sale for $3k with a dud motor.
you definitly want a builder with RB expertise..especailly seeing as how much problem you have had already. My mate builds and machinings all his
motors(hes a machinist by trade), and has built lots of tuf Rb's....theres a few tricks machining the oil galleries and bottom end clearance wise to make them live.
I have seen that many monkeys f**k them up its not funny..lol, especailly blocks bored with a torque plate and ended up with oval bores, used to happen alot 10+yrs ago when v8 machinists started building jap stuff, alloy blocks are worse, but seen big dollar Rb30's f**ked the same way
cheers
darren
Edited by jet_r31
I thought neos used an n1 pump?
My turbo is a hypergear atr43 ss-1. I'm planning on running about 220kw at the wheels.
errr hope not, you would spend half your life, cleaning out a catch can, or redrilling your 500th restrictor as the other 499 didn't stop the oil pooling up in the head..
you wife will love the smell of burning oil in her nice family car..lol
stock pump ftw, my mate doesn't use collars, he welds the crank and machines it down to fit tight over the pump gears..way better fit, way better quality after seeing how some of the
big dollar collars are attached, but unless your limiter bashing you probally don't need even a collar.
If it was me, i would rebuild it as a stocker(no forgies),but paying attention to clearances and machining/oiling systems
it would be better than a stanadrd motor(if you get the right person)
cheers
darren
Edited by jet_r31
Give the boys at SPOT ON PERFORMANCE
@ randal st slacks creek
Ask for Andy or danny they are personnel friends of mine
They have both worked on And built rbs and will be able to help u out mate if they can't they will tell u next best option
Also as chocco said go to Efi to get it tuned they are good with rbs
jet r31 can you please pm me some contact details please.
il go to nissan about an oil pump and a set of pistons tomorrow.
il give spot on performance a call tommorow, thanks for the info booztjunkey
contact details for who?, my mate?, he works out of his garage at home afterhours, during the day he works for the biggest machine shop in adelaide
so does all machine work there, and then brings it home for assembly, I can give you his details via p.m, but remembering its afterhours it takes a while and he usually has a
big waiting list. Very good priced though as no overheads. Having said that, engine builders in a workshop usually take forever aswell..lol
cheers
darren
yeah, you say he does a good job so its worth contacting him and asking what his thoughts are. in any case il be sending my block a long way for machining so may as well get someone experienced to do it. ive been talking to rips for a few weeks working out some options, just waiting on a price from them. not that im after the cheapest option just the best work for the money.
talking to RIPS wont be getting you anywhere near the cheapest option...
seriously...
you have gone above and beyond the guys here and from now on in this build is wallowing out of control
I dont even think you know wats goin on...
a standard engine IS all you want... put the damn thing in and sell it and get a toyota lexen or something
If your head is off and good then its probably worth contacting an importer about a bare long motor or even a half cut and sell off the stuff you don't need
Most places get whole cars, drive them to the container, then chop them up (usually after doing a compression test)
Unless you pay big bucks, you won't get an engine but to as good specs as what Nissan pumps out from the factory where they had guys just building rb's day in day out
You could get a short block and have it inspected, would probably be cheaper too
I tried to get a long block when I first started pulling the engine out, of the 9places I contacted only 1 had ever had a neo motor but didn't have any coming in for atleast 6 months if at all.
Chocco just stay the f**k out of my threads. No one cares what you have to say, and for christs sake learn to read
lol talking like this only makes you a bigger moron champ.
all of this because you know sqaut didly over a simple engine lol
I do hope that your backyard build + the exchange of hands engine lasts no longer
then a 16 year old in bed.
All along you had to do was just listen to the guys that have been there and done
this but no. You could have been up and running again but no. You could have sorted
this all out from the very start but again...no
Ill just sit back and watch this mull away and continue to laugh at your stupidity.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
