  • Replies 886
Ok. Timing. Orange is 0 degrees? Then every mark is 5 degrees? I used the loop at the back of the coil pack loom.
My timing was sitting on the 5th mark so 25*btdc? I have adjusted it as far around as I could get it and it starts at 10dgrees and slowly works its way around to about 16/17dgrees. Is this ok?
Should be around the 15deg I think
If it were me I would want It bang on that I dunno if tha 2deg adv will cause detination
But if u had it set a 25 deg bftdc that defiantly would not of helped anything and would have no doubt been detonating or not far of it :-/
Also most of the RBs I have owned have usually have there cas set in the middle .
Only once have I had one set on max retard and that was when my cas was on its way out and started advancing the timing randomly hahhaha
Good luck buddy
Yeah. I'm gonna make up a test lead and try it again. It doesn't seam right at all. It's running really well at the half way point where the old mark is. I just wanted to check
ok its back at about half way, on the 3rd line on the harmonic balancer.
did a compression test, 191 170 170 170 170 170 , but bear in mind that i had spilled oil and the 1st cyl copped a lil bit of oil that i couldnt get out with my rag, il retest in a week or so after ive done the 1000km.
but ive noticed that my pcv seal is broken in half. so i need to find another one of those.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
    • It doesn't seem to follow revs. Oddly it seems to follow TPS a little bit from what I can see, but with some delay a bit. IE end of the graph, when he lets off throttle fully, pressure drops a lot, then slowly builds back up, but rpm is on a nice cruisey drop off. I do agree though, it seems very electrically.
