  • Replies 886
Its good to know its possible to do the seal without pulling the pump off. Just a thought. If my front seal is leaking does that mean I need a new timing belt because it will be stuffed?
If you used a fresh timing belt, you don't need a new one. You've done less than 250km on that belt, waste of money changing it. Its not like you change your pulley belts everytime you take one off to get to something else.
Mmmm I don't think car oil has the properties to ruin a timing belt... Its made of material much MUCH tougher than rubber and oil doesn't eat rubber. It should be fine. Someone should confirm this, I don't want to be wrong and then the belt breaks..
Edited by SargeRX8
just to throw it out there - You really don't want a slippery belt on there.
And you must choose your cleaning solution wisely - or the belt WILL deteriorate..
Good to know this stuff. It seems logical to replace a $100 belt than risk a 5k engine.
The leak is very minimal, like there isn't a difference on the dipstick. Just a few drops on the floor. It didn't have leaks hen I did the oil change, but in the next 15km it started to leak :/
It's not the front seal. It looks like its coming from up higher. I can't see where but yeah. Maybe the oil pump bolts aren't tight enough? Is there actually much pressure behind the oil pump? There isn't a single spec of oil vapor in my breathers.
Whos the new workshop to blame now?
Was efi to start with now who?
Name and shame your wonderfull work
What's it to you man? Why is it so important to you that every time something goes wrong with Steven's build, you are there to rub it in his face?
Why is anyone to blame at all. It's an oil leak. And I do still have negative things to say about 2 businesses at yatala, I just know its not worth worrying about it anymore. Proving their lack of quality work won't fix the problems or put the money back in my pocket.
I was actually wondering when you would be back.
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
