  • Replies 886
yeah it does some crazy stuff and should probably be left alone
i've head ppl also say that you should take a boost source after the cooler and even from the manifold, i guess to counter the boost drop across the piping and cooler core
I wouldn't. What happens when you do for some reason get a massive pressure drop across the system? Most people (with a Hypergear turbo at least) will use an actuator that is rated close to their turbo's maximum efficiency. But if your turbo is efficient to 20psi and you have an actuator that is rated to 20psi hooked up to the manifold, and you get a 5psi pressure drop, then all of a sudden your turbo will be trying to push 25psi, which could lead to super-heating of the intake charge or outright turbo failure.
I would have the nipple as close to the turbo outlet as possible. Then at least if you get a pressure drop, you're just going to lose a bit of power and you will notice and get it sorted out.
There are lots of fors and againsts.
Some people claim it using manifold causes boost spikes as you run a longer actuator line as well as a longer pressure source etc etc.
I used to run my old TD07S off the manifold, never had boost spike issues, and I actually had a reason... I had no BOV, there fore I wanted my pressure source to my wastegate in vacuum during gear shifts rather then seeing the huge pressure in the cooler pipes. This forced the wastegate shut whilst shifting, and made the car come back on boost hard again...
But on a nice little street setup, I'd have the pressure source as close to the turbo as possible.
Ok now I can smell oil through my air con, anyone ever had this, I can't find a leak but yeah kinda weird.
OK, pretty simple mate.
Your AC picks up fresh air from the skuttle panel (where the wipers are), anything that comes out of your bonnet would get sucked into there while your driving.
If your PVC is rooted and letting boost into the sump then you are probably pushing fumes or oil out of the dip stick. Furthermore if you have done a half job of your oil breather system (noting you dont have it running to your intake pipe anymore) it would also be doing the same thing. Otherwise if you have a little airfilter on the end of your rocker breathers it could be that too.
Yeah I thought that, it only really happens when I brake. One day was a really bad fuel smell the next it was oil, that's what had me poking around and I can't find anything. Guessing it's just another quirk.
Reading through all this and the other crap that youve posted all points to one thing
You shouldnt be around cars cause by the information or lack of you do give us you dont even
know wat the f**k your talkin about.
"DAMN I GOT NEW TYRES AND NOW MY GARAGE SMELLS LIKE NEW TYRES"
I mean your persistant ill give you that but seriously do you even know wat the f**k your on
about?
By the sound of it all just sell the car and buy a push bike...
We can then see threads of "How do I lube my chain" or "Im stuck in 15th gear HALP ME"
yep sorry but this is getting funny now....
Why are you not just taking your car to a decent mechanic/tuner, really these issues your having don't sound that hard to fix really....
He will prolly blame the tuner for not having a clean smelling car soon cause of this oil/fuel
vapour thats leaking out...
"YOUR TUNE IS SHIT, MY CAR IS STINKY NOW :( I DONT LIKE YOU!"
Really reminds of of all the halfwits at work that find the old point and blame game alot easier
then just saying "Yes I f**ked it by doin blah blah blah"
Just sell the f**kin thing and rid yourself from this site...You remind me of a smarter version
of La Bomba.
Chocco you never cease to amaze me with your completely useless posts. For some reason you feel that people aren't allowed to learn about the causes and fixes for their mechanical problems.
For those interested it appears some of the oil drains in the head were blocked.
Come on leave the poor guy alone, he is trying to learn.
lilcrash all I can suggest is if someone offers some advise that sounds reasonable then follow it and give some feedback/results <- Which you have actually been doing, apart form the odd delay.
Keep cracking on you will sort it out sooner or later.
alot of the delays in testing is because i get stuck into working on my wifes car and forget about my own problems. her car is still running perfectly without an afm and it runs like shit when i plug it in. im very confused how thats possible but yer.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
