  • Replies 886
no you don't
Absolutely do, I recon id get even down to 8.5-9 on a highway. Its tuned quite lean at cruise, as far as it can without being dangerous. Down side i can only use 98+ octane fuel. But even if i drive hard in traffic i get about 11-12 :-)
Alot of WOT and the fuel goes down as the speedo goes up lol
is your car stock std?
other than a complete std r33 with a tuneable ECU could you get 11-12 driving it hard in traffic..., unless your not driving it hard at all...
$1500 trade in value... wtf..?
thats pretty darn crap... strip it for parts
Did you turn O2 feedback off and lean it out at cruise? If you did that I could believe it, but with stock O2 feedback unless it is entirely highway kms with basically no boost Im sceptical.
I reckon lots of parts could be sold to make alot more than $1500
it all depends how much you owe on it...
you dont want to end up being in debt for more than the asset you have on hand is worth, thats just silly...
No, i am being unfair in not mentioning im running map haltech e11v2 and im running a t04z so I dont get good boost till 3k and solid boost untill 4800 revs so its easy to not use alot :-)
A lot of my driving is main roads/highways but lots of hills... even in citys i still get under 12
I don't enjoy my $90 a week fuel bill. 15/16litres per 100km
yep, they are f**ked, having come from a magna wagon which does 11.9-12.3 in city, it was a rude shock..bit better with exhaust/cooler etc now..going to get it road tuned with nistune for sure...
cheers
darren
Hmmmm maybe you should have bought a second hand engine like everyone said last year.
BTW i got 515km out of my 33 without the light coming on :) Best i have done so far. Did a few off the clock runs as well (private property of course)
how would that affect my fuel usage?
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
