Import Monster Sauvic Deca Motorkhana - 2011 Round 4
Proudly Presents:
Import Monster SAU-Vic DECA Motorkhana ROUND 4 of 4 of the 2011 DECA CHAMPIONSHIP
When : Saturday 19th November 2011
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $85
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. :HERE!
NO PAYMENT, YOU WILL NOT BE ON THE LIST
FILL OUT FORMS COMPLETELY. INCOMPLETE FORMS WILL NOT GO ONTO ENTRY LIST.
***Also, if you are emailing you entry, please name the attached file after your full name and what page it is. eg. 'Ryan Bell Disclaimer'.
Event Schedule: Here
Results: Not yet available
All withdrawles will be refunded after the event. Refunds will not be given after 5pm Monday 14th November.
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Import Monster Pty. Ltd. Factory 3, 6 Wigan Road Bayswater VIC 3153 (03) 9008 0031
  • Replies 154
Posted Images
Entry List:
1. Import Monster Russell Cunningham R32 GTSt
2. Import Monster Christopher Lethbridge Corlla
3. Leon Stapley 180sx
4. Ryan Bell sileighty
5. Bec Pretty Mini
6. Jon Evens R35 GTR
7. Sarah Flynn Mini
8. Shane Janssen R33 GTR
9. Campbell Shobbrook 180sx
10. Mario West Evo 8
11. Jake Lowry 200sx
12. Ashwin Rajan 911
13. Akshay Rajan 911
14. Simon Wilcox Chaser
15. Ashneel Prasad Mark 2
16. Phil Mak Silvia
17. Terence Ho R33 GTSt
18. Josh Miller R32 GTSt
19. Simon Henman R33 GTSt
20. Daniel Robson Ae86
21. Martin Sullivan 200sx
22. Ryan Mcpherson 180sx
23. Davis Hurst R32 GTS4
24. Jett Benson 180sx
25. Dean Course R33
26. Gerald Tan Surpra
27. Jessica Trabert R33 GTSt
28. Linley Baxter 911 GT3
29. Simon Baxter SS Ute
30. Andrew Stevenson R32
31. Daniel Taylor S14 200sx
32. Chris Taylor
33. Bradley Humphrys R32
34. Brent Germain R33 GTSt
35. Brian Haines R35 GTR
36. Matthew Femino R32 GTSt
37. Mitch Payne VX SS
38. Mark Ryan R33 GTSt
39. Stan Lubinkov Forester XT
40.
41.
42.
43.
44.
45.
46.
47.
48.
49.
50.
Reserve:
1.
2.
3.
4.
5.
8
I'm sure some peeps will be first realising this while drunk on Friday night, and start throwing their entry money at you guys to guarantee their spots :P
Entering now :D
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
